NAPA 3818 fuel filter replaced 3518
Just went to NAPA to get a new fuel filter and was informed the old PN 3518 was replaced with PN 3818. The fuel cartridge/filter looks identical, however they have replaced the beveled gasket with a square cut one. In the instructions it reads "...this cratridge style fuel filter comes with a square cut gasket not a bevel cut one so change outs are completed quickly and with no confusion over gasket positioning." Has anyone else already used this new style? Has anyone else already used this new style, and how did it work out? If this is old news, sorry, I just know I have read posts talking about placing the bevel gasket in the "right way" to avoid leaks. Thanks,
Yes they only sell the one piece filters now. But I had good luck with it, no leaks at all the first time putting it in. So no complaints here. I did notice that since the whole assembly turns while screwing it on it took a lot of diesel to lube it so it turned easily. At first it felt like the o-rings were binding up a little bit, so I took it back out. I considered using some oil instead, but I still had the cup of diesel from the drain and just soaked it. Went in nice and smooth after that. I kind of like the one piece assembly and the no brainer square gasket so far.
The new NAPA filters with the cover and square gasket are no problem. NAPA has actually improved the cover since they introduced their first one piece. Now you can use a common socket wrench to loosen and tighten. That is a great improvement over the old channel-lock trick. I change my fuel filter every 5000 miles, along with air and oil. May be a little excessive, but I get great hand calculated fuel mileage, and it has to contribute to the longevity of the motor and pump. The last one I bought was $19. I must admit though, I didn't like their new one piece at first, but with the improved cover, I have re-evaluated my thinking. NAPA calls the new square rubber seal "error proof."
The one a got a few weeks ago didn't have the ability to use the 3/8" ratchet. The one I took off did, but the new one I had to use the channel locks. So I either got an older one, or they changed it again.
The one thing I did notice on that filter was that in one spot the pleats were spread apart more than I'd like. Not sure what the deal is there, but if the next one is like that I might look for a different brand. Doesn't look quite right to be like that.
Received 3,110 Likes
on
bulletpruf
30
12-26-2015 12:56 PM
FreeDevin
06-13-2015 09:23 AM
sowaxeman
04-15-2015 06:50 AM
