Motorcraft Fuel Filter FAIL
This is the gasket out of the box. I gently got it to fit in the bowl and carefully tightened it down, cleaned the area and observed no leaks. Drove about 15 miles and it failed on me requiring a tow because of where I stalled.
The purolator replacement I got has the flat gasket and fits much easier. Returning this to dealer today.
Yeah, it almost looks like an empty bowl with just fuel in it.
WHOA... forget what I said in my earlier post!!
Now that I look at it closer, I believe it IS an empty bowl after all, and what we're seeing is fuel sitting in there without the filter element. I can see vaguely the heater coil through the fuel around the edge of the bowl.
OK... back up then and recalibrate. I see two potential failure points...
1) An oversized gasket o-ring due to poor QC when the filter element was packaged at the manufacturer, or
2) A failed (warped) fuel bowl lid.
I believe the bevel is correct in the OP's picture. If you zoom up close where the gap shows up and look carefully at about the 2:00 position where it meets the raised fuel bowl sidewall lip, it appears that the straight inside edge of the o-ring is up against the lip as it should be... at least that's how MY eyes see it.
I really think it was just a packaging mistake with too large of an o-ring to begin with.
Fellas, the bevel is up and the fuel bowl isn't empty.
Freesoul, the motorcraft packaging has exact instructions. Are you running an aftermarket cap, lets say a luberfiner.........
Did you lube the gasket before install? Did you place it on the lid or on the bowl before install???
Tightened beyond spec will spit that baby out like my parents used to in the 60's.
Puro filters and gaskets are not the dream team.
Denny
BTW short story, On my way to take the kids to the circus 45 miles south. Michigan winter. Just serviced my filter and always carry a spare onboard. _0 degrees out light snow. Full tank. I get half way and notice my fuel is at half. First exit, off I go. Pull into a fuel station and pop the hood....heavy fuel in the valley and under the truck.
I can't feel my hands, so I just grabbed the spare, installed it correctly and continued on. Got to the circus, 1/4 tank now, should have paid more attention but with the kids and elephant dreams of rides, that went south. Was in the negs so I remote started the truck before the show ended. Walked up to the truck (running) and saw at least 5 gallons of fuel on the ground. Shut it down, checked the fuel filter housing. It was bright enough in the parking lot (yet bitter cold and blowing) to pull my new filter and inspect. The metal plate on the bottom of the element came off the original filter which didn't keep her from running, but wouldn't let the new filter get tight enough to seal the gasket surface. Took less than an hour to run thru a full tank and so glad we didn't get a flame on.
Most people as I did, take this simple maintenance task lightly. Fact is, I could have lit that whole arena up with parked cars because of my hasty situation and inept diagnosis.
Thanx for the patience, but make damn sure what ever you put in, you get out.
Denny
Denny
Denny
Just to add, I don't see in your bowl the fuel heater which should be readily evident unless it's glare. Everytime you change your filter, everyone recommends to pop your drain valve on the back to discharge contaminents and water as well as exercise the valve.
Wipe out the bowl for turds and go with everything fresh. KOEO a few times for 30 seconds and start and inspect for leaks.
Sorry about the double post, but it is very important to do this one truck burning venture accurately and with due diligence.
Salute,
Denny
Salute,
Denny
That's been quite a while ago, and I have never had another one come apart like that. I have also never had to use that much torque on the lid since to get a leak free seal.
But you can bet I look out for it every time I change the filter now!!
