Steering Wheel Hub Bolt
Old Mar 27, 2017 | 12:14 AM
4yrhealth's Avatar
4yrhealth
I have a speedometer/odometer in a 1998 Clubwagon that's not working. Want to pull the wheel and dash to get a look back there. Manual says I should discard the old bolt and get a new one for reinstallation.
Is this necessary? I don't mind buying a new bolt, but I'm having a very hard time finding info or a part number on one.
Old Mar 27, 2017 | 08:30 PM
98Econoline150's Avatar
98Econoline150
I would absolutely follow the Ford recommendation for discard parts.
Old Mar 27, 2017 | 10:02 PM
4yrhealth's Avatar
4yrhealth
Probably not a bad idea to follow the instructions...
Any leads on replacement steering hub bolts? Is this bolt model specific?
Old Mar 27, 2017 | 10:06 PM
98Econoline150
I'd try the Ford dealer at least you can get a part number out of them if nothing else.
Old Mar 28, 2017 | 10:26 AM
Im50fast's Avatar
Im50fast
If it doesn't have any unusual characteristics I would reuse it.
Easy for for me to say though because it's not me
Old Mar 28, 2017 | 04:10 PM
vettex2's Avatar
vettex2
they say re-use due to liability/lawyers
I wouldn't sweat it
Old Mar 29, 2017 | 08:31 AM
Wildman25's Avatar
Wildman25
I wouldn't sweat it
Agree.
Besides, the steering wheel needs a puller to get off the stem.
It's literally pressed on the shaft.
Old Mar 29, 2017 | 08:36 AM
Teutonics's Avatar
Teutonics
If you're concerned about it working loose after reinstall, put some blue loctite on it.
Old Mar 30, 2017 | 02:44 AM
4yrhealth's Avatar
4yrhealth
Local Ford deal has been unresponsive. Planning to operate either before or after this coming weekend.
Thanks for all of the input, I have some blue loctite on hand just in case.
Old Apr 7, 2017 | 01:34 PM
mccullek's Avatar
mccullek
I just swapped out my steering wheel. The bolt looked no different after I removed it. I tried to buy a new one locally and could not find one, so I put some locktite on it and put it back in without any issues. My opinion only.... you don't nee a new bolt unless the one you took out is damaged maybe?
Old Apr 7, 2017 | 02:56 PM
Tedster9's Avatar
Tedster9
The older trucks, the manual suggested staking it with a punch.
Old Sep 12, 2017 | 10:17 PM
4yrhealth's Avatar
4yrhealth
Found today that it is not necessary to remove the steering wheel to get the instrument cluster out on my 98 Clubwagon. Really pretty easy.
Just needed to remove six 7mm bolts (2 from the roof of the cluster housing, and 4 from each corner of the cluster), pinch the gear indicator clips inward, and pinch + pull the 3 clips on the back of the PSOM out.
Kind of common sense, but shifting the gear selector into its lowest position at 1 will help to create a little more space for removal and install.
TPyle
Jul 6, 2014 03:26 PM
EX40
Jun 18, 2008 08:04 AM
Stangfire
1997 - 2003 F150
Apr 22, 2005 07:57 AM
79 390 highboy
Jun 19, 2003 09:03 PM
steve83
1978 - 1996 Big Bronco
Dec 29, 2002 07:25 PM
