Steering Wheel Mounting Bolts
Old Jul 4, 2014 | 01:49 PM
TPyle's Avatar
TPyle
Sorry if this has been asked before...I did a search and couldn't find the answer to my question. My truck has a non-stock steering wheel mounted to what looks like the original "collar" ( I might be using the wrong term). However the 3 bolts that help hold the steering wheel to the collar are not the correct size as they are loose and will not tighten. What size are those bolts supposed to be?
Old Jul 4, 2014 | 04:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The steering wheel is retained to the splines of the steering shaft with 350983-S nut. There are no bolts of any kind.
Old Jul 4, 2014 | 05:26 PM
P38fighter's Avatar
P38fighter
You probably have an aftermarket "hub" and wheel. Are the bolts too long and thus the wheel is loose or are they not the correct bolt for the threads in the hub? Remove all the bolts and get a bolt gauge or by trial and error find a bolt that fits properly. Post a picture if you can.
Old Jul 6, 2014 | 03:26 PM
TPyle's Avatar
TPyle
Thank you for the replies...it would seem that the latter is the case. I assume that the hub is aftermarket. Thanks again for the replies.
RedFordRob
Jan 15, 2019 08:52 PM
highoctane74
Oct 14, 2016 08:47 AM
Matt1966
Feb 25, 2016 03:58 AM
rocknrod
1997 - 2003 F150
Mar 13, 2014 09:06 PM
sas
Aug 13, 2004 03:08 PM
