97 7.3 no start
Old Mar 25, 2017 | 07:18 PM
Woodsgirl's Avatar
Woodsgirl
97 7.3 no start
I have a 97 7.3 powerstroke.
Truck was running, lost two injectors unplugged the bad injectors, truck still ran missing 2 injectors. I bought new injector from SwampDiesel, Got Injectors installed everything back together. Truck will not start, Truck tries start, but no smoke coming out tail pipe. I get no codes from the computer either. I have checked and rechecked connections. I find no fuses blown out. I have oil pressure and fuel in the bowl. Help Please
Old Mar 25, 2017 | 07:47 PM
quesey's Avatar
quesey
It takes awhile of cranking after installing injectors to get it to fire up. Has to fill everything back up with fuel and oil
Just crank it over about 15 sec then wait a min or so and try it again
Old Mar 25, 2017 | 07:51 PM
Woodsgirl's Avatar
Woodsgirl
[QUOTE=Woodsgirl;17062607]I have a 97 7.3 powerstroke.
Truck was running, lost two injectors unplugged the bad injectors, truck still ran missing 2 injectors. I bought new injector from SwampDiesel, Got Injectors installed everything back together. Truck will not start, Truck tries start, but no smoke coming out tail pipe. I get no codes from the computer either. I have checked and rechecked connections. I find no fuses blown out. I have oil pressure and fuel in the bowl. I have been cranking engine about 40 seconds on 40 seconds off. I have burned up one starter. HELP PLEASE
Old Mar 26, 2017 | 10:42 PM
Woodsgirl's Avatar
Woodsgirl
Okay truck still cranks over and still not start. I still get no smoke white or black out of tail pipe when I am cranking engine over help please
Old Mar 26, 2017 | 11:01 PM
Woodsgirl's Avatar
Woodsgirl
Could I have a bad IDM
Old Mar 27, 2017 | 07:10 AM
PSU4ME's Avatar
PSU4ME
I would not suspect the IDM given what you've said. What else was touched when you did the work? Is the cps good?
Old Mar 27, 2017 | 07:23 AM
BuddyBarnes's Avatar
BuddyBarnes
Also check your fuel pressure. Just because you have fuel in the bowl does not = pressure.. Easy check with tire gauge
Old Mar 27, 2017 | 08:00 AM
knottyrope's Avatar
knottyrope
you are not waiting long enough to cool it. 30 sec crank, 5 min wait
download and print this no start flow chart
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Old Mar 27, 2017 | 08:31 AM
madpogue's Avatar
madpogue
Can your device do a buzz test?
Old Mar 27, 2017 | 10:48 PM
Woodsgirl's Avatar
Woodsgirl
I have replaced camshaft sensor and fuel pump under the fuel bowl. I have checked fuses underhood and dash, I get no codes or any edidit lights to come on. The truck turns over but no start and no white or black smoke out tail pipe. I have also burned up two starters. Help, appreciate all the help
Old Mar 28, 2017 | 03:31 AM
Kingkong0192's Avatar
Kingkong0192
Stop firing the parts cannon at it.
I know you want to just crank and crank and crank and hope it fires up but clearly that's not working.
Check everything you touched. Make sure all the sensors are plugged in. Check the IPR sensor right near the fuel bowl. Make sure you didn't accidentally bump it with something and break it.
Old Mar 28, 2017 | 07:07 AM
BuddyBarnes
Have you followed the flow chart knottyrope posted is post #8? If not try to follow that chart step by step. Do not skip a step. It Is a good chart.
Old Mar 28, 2017 | 07:55 AM
knottyrope's Avatar
knottyrope
do you get a wait to start light to come on?
Old Mar 29, 2017 | 04:54 PM
madpogue's Avatar
madpogue
Repeat - can your device do a buzz test?
dondolittle2
Jul 15, 2022 07:55 PM
1bigjoe
Aug 4, 2019 06:32 AM
LI John M
16
Aug 13, 2016 09:12 AM
clint stafford
Aug 27, 2014 09:08 PM
joker67735
Sep 12, 2013 09:28 AM
