How do I prime injectors
There is no priming. Just keep cranking until it eventually fires. I usually crank for 15-20 seconds, let it rest for a few minutes to cool the starter, then try again. 3 or 4 times doing that it should fire, stumble and run rough for a minute, then start smoothing out. You'll see smoke out the tailpipe for a while. Just take it for a 20 minute drive to clear things out.
You did evacuate the cylinders right? When you pull an injector all the fuel and oil runs into the cylinder. It needs to be evacuated before you crank or you'll seriously risk hydrolock.
94 to 97
You have a mechanical pump. Unplug your injector GP harnesses turn your truck over for 20 sec. Wait and repeat process then plug your harnesses back up or you could pull fuel through the return line with the Schrader valve on the filter housing you want to have fuel in the injectors to keep from damaging your tips no dry start
joker67735
09-12-2013 09:28 AM
