Sponsored by: Real Truck
Alternator question
Old Mar 23, 2017 | 09:57 AM
Raw5768's Avatar
Raw5768
Alternator question
Will a 2005 alternator fit on a 2006? Single alternator system on f250 superduty diesel
Old Mar 23, 2017 | 10:54 AM
Mike189677's Avatar
Mike189677
As long as both trucks are diesels it will fit but as important as voltage is to those trucks getting a good new alternator with a minimum of 140 amps of output not one out of another truck from the wrecking yard or whatever in unknow condition and making sure both of your batteries are up to snuff by having them load tested separately out of the truck they should also be replaced in pairs if needed. There is a good thread about alternators in the 6.0 section of the site I would recommend you read through it.
Old Mar 23, 2017 | 11:52 AM
droldsmorland's Avatar
droldsmorland
Why not call a good parts house and have them look up both applications to see if they are the same?
Old Mar 23, 2017 | 11:58 AM
Bumblebee04's Avatar
Bumblebee04
If replacing the stock alternator, there's no way I would stick with the grossly underpowered stock setup. Check out FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts if you want to replace it with a sufficient output alt.
Old Mar 23, 2017 | 12:20 PM
Jaime74656's Avatar
Jaime74656
If your engine is (iirc?) the 7.3 hey the 6.0 alt mine is the 140 (or 160, can't remember what's there right now) it will fit with very minor modding to the bracket (self evident) when you offer the alternator to the truck…
Old Mar 23, 2017 | 03:47 PM
silverbullet6oh's Avatar
silverbullet6oh
Originally Posted by Mike189677
As long as both trucks are diesels it will fit ..............
This is correct.
Ed M.
Aug 2, 2013 08:36 AM
wiznozniak
Jul 18, 2011 03:40 PM
sandaholics
Jan 7, 2008 09:39 PM
buckweet1980
Aug 21, 2007 01:59 PM
amulford
15
Feb 26, 2006 12:11 AM
