Transmission Problems / Recall
Old Mar 24, 2017 | 05:36 PM
  #31
BowtieConvert's Avatar
BowtieConvert
Dammit! Another weekend without my truck. The parts came in today and supposedly they will have it ready Monday afternoon. Don't know what parts they had to replace but I will find out then. Meanwhile I'm tooling around in my stylish 3500 HD flatbed. LOL.
Old Mar 24, 2017 | 05:43 PM
  #32
PwerStroke99's Avatar
PwerStroke99
Originally Posted by EpicCowlick
Mine was built 13 October and I have received no notices. Ford Owners .com also shows no recalls or field service actions for my truck. I check underneath the truck every few days and the trans cooler lines are dry as a bone.
Mine didn't show up right away when I heard rumor of this. Don't think the message gets out to everyone right away
Old Mar 24, 2017 | 08:24 PM
  #33
Rutcutter's Avatar
Rutcutter
Guys I got my letter yesterday and called my buddy at the dealer,checked they had the bolt and washer in stock and going to install the recall and install the update for the DPF% screen on the dash for me and whatever updates are out there...
Heard there is another update to increase power... Will find out in the morning.
Old Mar 24, 2017 | 09:35 PM
  #34
HRTKD's Avatar
HRTKD
Thanks for the teaser. I may not sleep all night just thinking about it!
Old Mar 25, 2017 | 12:26 AM
  #35
Rutcutter's Avatar
Rutcutter
Will find out in the morning! The head Tech that does all my work is usually "on top of everything",says there is an update file out..
Old Mar 25, 2017 | 12:50 AM
  #36
FONRDAY's Avatar
FONRDAY
I also got letter today
My build date was end of september geez
Old Mar 25, 2017 | 11:43 AM
  #37
Rutcutter's Avatar
Rutcutter
Got the TSB completed and the DPF filter screen enabled and he was right,mine had all kinds of updates to do...
PCM,TCM and a whole list of others to be updated.. Just put a few miles on it with the new programs and the truck is a good bit stronger and a different shifting strategy..
Old Mar 25, 2017 | 02:25 PM
  #38
wb6anp's Avatar
wb6anp
Mine goes in on Tuesday for a t-case seal, again, Ill ask about the updates.
Old Mar 25, 2017 | 02:47 PM
  #39
Kenv's Avatar
Kenv
Epic....which side of the truck should I look under to see where it "would" be leaking....passenger??
Old Mar 25, 2017 | 02:55 PM
  #40
Rutcutter's Avatar
Rutcutter
Kenv look on the Exhaust side of the truck.
Old Mar 29, 2017 | 06:30 AM
  #41
hmcfly's Avatar
hmcfly
I got mine done yesterday and the dealer told me that they put in a bracket to help hold the transmission lines.
Old Mar 29, 2017 | 06:56 AM
  #42
HouseMouse's Avatar
HouseMouse
Mine is going in today.
Old Mar 29, 2017 | 09:24 AM
  #43
Bigdon68's Avatar
Bigdon68
Inspected by Dealer -- no problem
Originally Posted by Bigdon68
Got my letter on Monday and am taking my F450 in tonight (Thursday) after work. The inspection and repair is apparently the O-RINGS on the transmission fluid cooler tubes.
No problem now but I'd better get it checked.
bigdon68
Took my truck in. They inspected the truck and it did not need any repair. If it ain't broke --- don't fix it.
bigdon68
Old Mar 29, 2017 | 09:38 AM
  #44
wb6anp's Avatar
wb6anp
The repair is to add a bracket or washer to prevent a future failure, if you got the letter the dealer needs to add that washer.
Old Mar 29, 2017 | 02:45 PM
  #45
HouseMouse's Avatar
HouseMouse
Mine is fixed now. Took about 45 min.
