Disabling door chime
Certainly I can share. Go to the first thread linked below and learn all you can about Forscan ... primarily, check out the Forscan spreadsheet for Super Duty trucks. Then make certain you study & obey everything in the Forscan tutorial linked further below. Is it easy? Yeah, but only after you take the time to learn/comprehend & spend the $$$ for the tools to make it work correctly.
https://www.ford-trucks.com/forums/1...readsheet.html
https://docs.google.com/document/d/1...gF1wxIqxY/edit
dont you have a push button on the platinum? The door chime only goes off like 3 times then stops with the push button.
you can do it 1000 times. The idiot that posted that set of instructions clearly didn't read the original topic. That is only to disable seatbelt chime not for the door open. The seatbelt is the easiest thing to bypass with wires, or a dummy buckle or buckle behind the back. Nobody ever in life needed that set of instructions
If for a 2023+ search in the ForScan 23+ thread. I did door chimes, seat belt chimes and the reminder on the center dash display.
https://www.ford-trucks.com/forums/1...l#post20963624
#30
GWIGG
1983 - 2012 Ranger & B-Series
11-16-2008 12:38 PM
johnfav
09-25-2004 07:20 PM
