Certainly I can share. Go to the first thread linked below and learn all you can about Forscan ... primarily, check out the Forscan spreadsheet for Super Duty trucks. Then make certain you study & obey everything in the Forscan tutorial linked further below. Is it easy? Yeah, but only after you take the time to learn/comprehend & spend the $$$ for the tools to make it work correctly. https://www.ford-trucks.com/forums/1...readsheet.html https://docs.google.com/document/d/1...gF1wxIqxY/edit
Thanks for your quick reply. worked like a charm. folks like you make the internet great! i would like to disable ALL chimes but haven't found that yet.
tried this today about 14 times. Finally got fed up cause it wasn’t working. Will try again in a bit
you can do it 1000 times. The idiot that posted that set of instructions clearly didn't read the original topic. That is only to disable seatbelt chime not for the door open. The seatbelt is the easiest thing to bypass with wires, or a dummy buckle or buckle behind the back. Nobody ever in life needed that set of instructions
I still haven't figured out how to delete door chimes on my 2024 F250, thought I did but was mistaken. I don't see a code change in forscan, hoping and waiting for new code
@oyster
See my post below. This worked on my 2024. Try searching in the 2023+ ForScan thread. More likely to find an answer there.
