Need some information
Old Nov 17, 2003 | 10:52 PM
Donald Rohret's Avatar
Donald Rohret
Question Need some information
My last thread was getting too long. But I need some information regarding door chime alarms. If someone would tell me how their chime alarm reacts under certain circumstances it would tell me a lot about my problems. Both of the following questions assume that the engine is off and the key is removed from the ignition switch. 1. If you turn on your dome light with your variable panel light brightness switch, and open your driver's door, does the chime alarm sound? 2. Now close the driver's door and open the passenger door and turn on your head lights and does your chime alarm sound? I would appreciate any information.
Old Nov 17, 2003 | 11:44 PM
Rogue Wake's Avatar
Rogue Wake
I've noticed no difference in response to the dome light. The door will chime in conjunction with the light staying on if the car was not running when the door was opened. I.E. the first time the driver door is opened after shutting off the engine, if the keys have been removed from the ignition, the chime and light will not go on. Having the driver seatbelt buckled also eliminates the light and chime. My passenger door has no effect on the chime, light is on only when opened. But all of that is just on mine. Hope it helps,
