Door Chime - Page 42
Before following the procedure, make sure that:
* The parking brake is set.
* The transmission is in park (P).
* The ignition is off.
* All vehicle doors are closed.
* The driver seatbelt is unbuckled.
1. Switch the ignition on. Do not start the engine.
2. Wait until the seatbelt warning light turns off (about one minute). You must complete Step 3 within 30 seconds after the seatbelt warning light turns off.
3. Buckle then unbuckle the seatbelt three (4 ?) times at a moderate speed, ending with the seatbelt in the unbuckled state. After Step 3, the seatbelt warning light turns on.
4. While the seatbelt warning light is on, buckle then unbuckle the seatbelt. After Step 4, the seatbelt warning light flashes for confirmation.
* This will switch the feature off if it is currently on.
* This will switch the feature on if it is currently off.
I don't think its an option to shut the door chime off. I'm gonna find the switch or the chime and stab it.
The Volume of the chime should, at the very least, be adjustable.
In my '02 I tore the steering column down and cut the appropriate wire to disable the key in ignition/door open chime. It was driving me nuts.
In maintaining our property I am constantly stopping with door open and engine running and that chime was very irritating. I also disabled the seat belt alarm as I don't need a seat belt while on site.
I will be standing at the ready with wire cutters when my truck comes in if anyone figures out how to disable these alarms.
Back in the old days, we would disconnect a wire from the actual chime that was located under the dash. My old Ram and Durango, you could disable it through programming.
Does the SD use a physical chime device or is it just a sound played through the speaker system?
Anybody disabled the door chime or killed the chime?
Had our 2018 F350 apart today. Had no luck. Wasn't like the 2012 or 2015 F350's we had. Just had to take the switch out on them and tape the contact. On the 2018, I had the ignition switch in my hand with the door open and the damn chime just kept going. Didn't see any contact to tape or wire to disconnect so I put it back together. Hope someone comes up with a way to disable it cause it drives a person nuts.
tried this today about 14 times. Finally got fed up cause it wasn’t working. Will try again in a bit
Certainly I can share. Go to the first thread linked below and learn all you can about Forscan ... primarily, check out the Forscan spreadsheet for Super Duty trucks. Then make certain you study & obey everything in the Forscan tutorial linked further below. Is it easy? Yeah, but only after you take the time to learn/comprehend & spend the $$$ for the tools to make it work correctly. https://www.ford-trucks.com/forums/1...readsheet.html https://docs.google.com/document/d/1...gF1wxIqxY/edit
