Nice truck/trailer! Did you simply add the airbags to the existing rear suspension or was it more involved? I have a Super Duty DRW on order and am very interested in learning more about your setup.
Thanks!
The air bags bolt in place with brackets that replace the rear bumper stops. Fairly straight forward installed and takes about 3 hours. I use the kit with an onboard air compressor and wireless controller. Allows you to adjust the air pressure from cab. The link below was the first one I found for the complete kit, however if you check around they can be bought much cheaper.
