My 2005 F150 Lariat 4X4 5.4L has a couple of issues.Can anyone please tell me more about the power mirror system without power folding. They quit working and checked all the related fuses shown in the owners manual numbers 3,4,8,18, & 114. All tested with my fluke and are good . Replaced the switch as per a Ford tech but still don't move. Heat seems to be working and all the other door switches the locks, windows and such!
Any other suggestions or advice about this issue? Is there anything in the power distribution box under the hood or anything anywhere someone may have knowledge of or a schematic that might help? If possible any help would be gratefully appreciated!!!
Thanks
Also have a battery draw issue that may possibly be related but not sure what the problem is there either. Replaced alt. with brand new not reman. Put in a six pack gel filled battery and still draws down INTERMITTENTLY, to a point to low to crank over and start after sitting for 4-5 days. It does this at times. I'm checking with fluke and it can sit for a couple weeks and only draw battery from 12.8 to 12.3, which sounds acceptable to me and starts right up. But then not changing anything or even driving it. Shut it down and after just a few days it may be down to 11.0V and so on. HELP PLEASE
