Windshield washer dribbles
Old Mar 18, 2017 | 03:13 PM
150Flare92's Avatar
150Flare92
On my 2000 OHV Explorer the windshield washer just dribbles. I purchased a new pump and still dribbles.
I took the nozzles and pump from my 2000 SOHC Explorer that worked great and put them on the OHV one and still dribble.
I even cleaned out the lines first.
Any pointers as to how to get these to function properly?
Thanks in advance.
Old Mar 19, 2017 | 09:31 PM
shorod's Avatar
shorod
Sounds like you still have a restriction in the line (kink maybe) or there's something blocking the flow to the pump in the bottle.
What method did you use to clean out the lines?
-Rod
Old Mar 20, 2017 | 07:59 PM
steve(ill)'s Avatar
steve(ill)
pull the hose off the pump and see that it shoots out 2-3 feet under the hood.. connect the hose and pull the hose loose at the firewall where it goes up to the nozzles and see that it shoots out at that point. I have blown air thru the line inside the cowl/ firewall with the nozzles removed, then reinstall nozzles... with nozzles out, see that the pump will shoot water up to the roof thru the hose....
Narrow it down part by part, starting at the pump output... could be the suction to the pump inside the tank is plugged.
Old Mar 23, 2017 | 04:56 PM
150Flare92's Avatar
150Flare92
I blew thru the line off the pump to the first connection I had removed and then with the connections off the cowl jets I blew thru that both ways. Still dribbled. I will try again.
Old Mar 26, 2017 | 09:21 PM
steve(ill)'s Avatar
steve(ill)
reconnect one at a time after checking PUMP OUTPUT.. verify that each hose AFTER the pump has proper flow......... if the pump don't have output, clean the SUCTION.
thordehr
May 2, 2019 01:27 PM
LongRider
General Automotive Discussion
Oct 2, 2018 05:33 AM
bigboylk
1978 - 1996 Big Bronco
Dec 23, 2017 03:48 PM
1980302windsor
Jan 18, 2012 01:36 PM
Dancingchicken
Jul 22, 2009 09:48 AM
