Timing
Old Apr 15, 2017 | 08:55 PM
  #31
Eric11973's Avatar
Eric11973
Originally Posted by Eric11973
here's an update on my 5.4 after replacing all the timing parts it ran good but I thought it was a little flat and it stayed that way for a couple trips then it started missing on cylinder 5 and 6 I checked the coil and the plug and the injector all was fine so I checked the compression and I only had 60 in one cylinder and 30 in the other I thought well maybe it did bend a valve so I pulled the heads and my exhaust valves were burnt what would cause The valves to be burnt like that and it wasn't just those cylinders it was seven out of eight cylinders the exhaust valves were burnt
my converters were cooked also
Old Apr 16, 2017 | 08:25 AM
  #32
alloro's Avatar
alloro
Engine overheating, poor fuel quality, to low of an octane fuel, just to name a few.
Old Apr 16, 2017 | 12:35 PM
  #33
Eric11973's Avatar
Eric11973
I've never noticed any over heating don't mean it never happened just never noticed it I always use bp gasoline 87 octane also the exhaust manifold was cracked on both sides wonder if that had something to do with it. The cylinder walls had a few nicks you could feel with a fingernail but I wouldn't tear it down for those little spots I got tired of messing with it and Me and a friend of mine pulled the engine out last week and I got a remanufactured and put in it
Zachery Blankenship
Mar 8, 2019 10:38 PM
dexterslab724
2004 - 2008 F150
Aug 12, 2017 12:51 PM
akorcovelos
Modular V8 (4.6L, 5.4L)
Nov 9, 2015 09:40 AM
wtmjr43
Jun 1, 2015 08:52 AM
jnhrtmn
Dec 6, 2010 08:33 PM
