Bouncing and Chucking solution wanted
Old Mar 15, 2017 | 09:11 PM
ssunit1's Avatar
ssunit1
I have a 14K lb 5er sitting on a Reese 21K hitch. Just recently got onto a bad road and thought I was on a bucking bronco, although I have only really rarely seen that on tv.
Anyway, I have a set of Timbrens that level the load just fined but recently I have been tossing arond the idea of switching to an air bag suspension or air bag pin box or air bag hitch. With a little bit of research I am now much more knowledgable and totally confused, even more than normal. But I did actually find out what chucking meant so the research was somewhat productive.
I know a bunch of fellow 5er haulers have the suspension bags but I am looking for some objective opinions from people that have any of these and whether they do what the advetisment promises.
Old Mar 15, 2017 | 09:47 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Andersen Ultimate hitch here with zero chucking and 49 lbs in weight for the hitch.
Just my .02
Old Mar 15, 2017 | 10:37 PM
P.Bronner's Avatar
P.Bronner
That trailer is more like 15,000 (+) with a typical travelling load. Air bags and a set of good rear shocks will help a lot. A Mor-Ryde pin box will help with the fore and aft chucking. I have a Montana that has a typical road weight in the upper 13's and pull it with the 350 in my sig. I am equipped as described and it behaves well even under adverse road conditions.
Now I'm going to tell you what I think you know but don't want to hear. You have too much trailer for that truck. That's 350 dually territory.
Old Mar 15, 2017 | 11:32 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
What I think you are feeling is the trailer stepping over bumps in the road, first does your trailer have shocks. I would also install Mor Ryde SRE 4000 equalizers, between the two they will dampen the axles on rough roads.
Denny
Old Mar 16, 2017 | 05:50 AM
camping nut's Avatar
camping nut
Air pin boxes do help a lot. Air bags in the rear suspension over the timbrens would also help as you can adjust the air pressure to the load. Those to things will help with the bounce (up and down) but do nothing for the forward and back movement.
Old Mar 16, 2017 | 07:40 AM
jsm180's Avatar
jsm180
Air bags adjust ride height only, the only improvement in ride is by getting the truck up off the overloads if you are squatting too much. Correct pin weight, air hitch/pin box and shocks on the 5th will help with chucking and bouncing if they are matched with good shocks on the TV. Just remember, some roads are just plain bad and no amount of money thrown at your rig will help, the only answer is to just slow down. I hit a section of I69 around Lansing, MI this summer and 45 mph was too fast.
Old Mar 16, 2017 | 07:52 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Louisiana, I 10 west bound... like driving down stairs... every concrete section .. 3 to 4 inch drop... even semi's go 35..... it about 20 miles long.
soil shift.... swamp land... bad design.. nothing will help.. avoid or slow down..
Old Mar 16, 2017 | 08:34 AM
rvpuller's Avatar
rvpuller
Been on that stretch of road nothing will help there.
Denny
Old Mar 16, 2017 | 01:18 PM
golfmedik's Avatar
golfmedik
Did the chucking just start on that road?? Or on others as well?? Usually chucking is caused by too light of pin weight, however if it hadn't happened before, it may be the shocks on the truck contributing to the buck. I've ran airbags on my last three duallies mainly to level them up, but I do have an onboard air system to adjust on the fly. When I hit bouncy roads, I can adjust the pressure to take out the jounce. Also, my trip from GA to Wisconsin Dells last summer proved to an eye opener as far as factory shocks. The Ford shocks were terrible, so I replaced them with Bilsteins and have been extremely happy. Even on our interstates around here I find myself adjusting the bag pressures a lot less to take out the bounce since getting new shocks.
Old Mar 16, 2017 | 03:16 PM
mrgrayaz's Avatar
mrgrayaz
Denny
Oh man we were just there - lost the valence over the front bedroom window, my coffee maker ended up on the wrong side of the trailer , pantry door opened and poured olive oil over the carpet...
NASTY bit of Road... Even then the ride really wasn't THAT bad in the truck.
Old Mar 16, 2017 | 06:25 PM
P.Bronner's Avatar
P.Bronner
Amen to that!!
Old Mar 17, 2017 | 09:49 AM
ssunit1's Avatar
ssunit1
Just my .02
Thanks for the reply. I contacted Anderson and they said that I am at the upper limits of the capacity of the rail mount ultimate. I just looked up the weight specs on your trailer and see that yours is about 1K lighter than mine, close enough for comparison.
Are you using the ultimate? If so do you have the goose neck coupling or the rail mount and are you using the safety chains. No videos of normal guys installing or towing show anyone using the chains.
Old Mar 17, 2017 | 04:46 PM
jsm180's Avatar
jsm180
The Andersen will not prevent chucking, it's still a solid mount the truck, only an air hitch will mask the effects of chucking.
Old Mar 17, 2017 | 08:25 PM
SRBF150's Avatar
SRBF150
The Andersen rail mount is rated at 20K and 4,500 tongue weight. That should be enough for you trailer?
I have the rail mount for a much lighter 5th wheel, you may see my thread on this:
https://www.ford-trucks.com/forums/1...sen-hitch.html
I will be installing chains soon for peace of mind using reese rail mount safety chain rings.
Overall, I love the hitch. I do have airbags and Rancho RS9000's set on firm when towing so I don't have chucking. Sous has airbags too.
Old Mar 18, 2017 | 09:55 AM
P.Bronner's Avatar
P.Bronner
This is drifting into a thread about hitches. The hitch isn't the problem here. The problem is an F-250 being overwhelmed by a trailer that weighs somewhere north of 7-1/2 tons.
