4WD not engaging
Old Mar 18, 2017 | 09:10 PM
  #31
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Originally Posted by Watcher58
Well heck Pirate, you are Mr Sunshine today aren't you??
In the spirit of the discusion, I assume the aftermarket hubs will not stay locked once they are unlocked?? If so, is it the spring size or just crap versus quality?
I have never had a manual hub stay locked after I purposely unlocked it.
Like 05mil said, it is more of a design issue then a quality issue with the OEM hubs. Because they operate on vacuum and rarely get used they just get sticky. I bet if you used them monthly they would have few problems until the hoses rotted.
Old Mar 18, 2017 | 10:44 PM
  #32
Stewart_H's Avatar
Stewart_H
I have one.
When I had Lavender Brothers weld that track bar bracket on for me, they discovered the Warn hub on the passenger side was stuck locked.
Stewart
Old Jan 7, 2023 | 03:00 PM
  #33
Chris camp's Avatar
Chris camp
1st Gear
My problem is I keep my truck in a4wd and just recently the 4×4 light started blinking
Originally Posted by Apocalypse
Personally I like my ESOF system. When I had issues I replaced the lines and anything else instead of swapping to manual. Up to you though.
My problem is the 4×4 indicator keeps flashing is that a concern because my truck still runs the same as always it just recently started blinking idk if it's low of gear oil or what thanks
PE1948
Jul 8, 2019 10:08 PM
viperbaron
Nov 27, 2014 10:42 PM
repster
Oct 19, 2009 11:36 PM
RedNeckSuperDuty4X4
Feb 19, 2007 10:15 AM
FilmGuy
Sep 13, 2004 02:37 PM
