Sponsored by: Real Truck
1999 SD 4WD Switch
Old Jul 8, 2019 | 07:46 PM
PE1948's Avatar
PE1948
1999 SD 4WD Switch
My 1999 4wd 250 diesel has an automatic trans, manual locking hubs and a **** on the dash to change from 2WD to 4WD Lo to 4WD Hi. I thinks its a pneumatic thing. The hubs lock, the switch seems ok, the 4WD indicator lites up on the dash. But the front axle does not engage. No engine codes. What to do? What to do?
Old Jul 8, 2019 | 10:08 PM
Fefanatic's Avatar
Fefanatic
OK, so you verified that the front hubs are locked into place? With the hubs engaged and truck on ground can you turn the front driveshaft by hand? If hubs engaged and driveshaft turns then it's a hub problem. It could be either or both. If the hubs lock and the driveshaft won't turn then they would be good and you would need to look at transfer case as issue. It's possible that the transfer shift motor is bad but my gut says it's the front hubs. Start there first.
Joemoy29
Apr 1, 2018 01:45 PM
Macmathews
Dec 15, 2016 04:25 PM
RedNeckSuperDuty4X4
Feb 19, 2007 10:15 AM
AKtruck
Modular V10 (6.8l)
Dec 19, 2006 02:32 PM
FilmGuy
Sep 13, 2004 02:37 PM
