Sponsored by: Real Truck
4wd Trouble,, Please Help
Old Feb 18, 2007 | 08:52 PM
RedNeckSuperDuty4X4's Avatar
RedNeckSuperDuty4X4
I have a 99 F250 SD with auto/manual hubs the "shift-on-the-fly" system.
If I turn the hubs to "lock" and engage my 4wd from the **** on the dash to 4-HI it works fine but when I turn the hubs to "auto" and engage 4wd the light on the dash panel comes on but I have no 4wd. I am thinking it might be the shift motor on the transfer case?? Please help with any info.
THANKS
Old Feb 18, 2007 | 09:01 PM
superdutyconst's Avatar
superdutyconst
Do front hubs slip in and out when in "auto"?
Old Feb 18, 2007 | 09:03 PM
75F350's Avatar
75F350
If the actuator was bad, you would not get 4wd when you lock the hubs. So the problem is in one of the hubs. It always is. You have one or both that is not engaging, and will not allow you to put power to the front wheels.
Old Feb 18, 2007 | 10:22 PM
99f350sd's Avatar
99f350sd
Those hubs are JUNK. Sorry,You'll have to see if you have the correct vacuum signal going to the hubs. If you do one or more of the hubs is bad or seals in that area are leaking.
Dick
Old Feb 18, 2007 | 10:46 PM
Musicman250's Avatar
Musicman250
My bet is bad seals in the hubs
Old Feb 18, 2007 | 11:03 PM
superdutyconst
Couldn't agree more 99f350sd. Just had both of mine replaced. Wonder if this issue was addressed on the '08s?
Old Feb 19, 2007 | 10:15 AM
99f350sd's Avatar
99f350sd
Probably use the same part number. I really suprised ford didn't do away with that system.
Dick
