Sponsored by: Real Truck
Factory Remote Start/Entry
Old Mar 15, 2017 | 12:58 PM
hd1937's Avatar
hd1937
My remote start/entry on my 2013 F250 won't work outside of 25 or 30 ft from the vehicle. On my 2011 it would work close to 100 yds away. My dealer has now idea why. Anyone run into this type of problem? Fixes?
Jim
And yes, I changed the batteries
Old Mar 15, 2017 | 02:19 PM
seville009's Avatar
seville009
You usually get two remotes; is the range the same for both remotes?
Old Mar 15, 2017 | 05:15 PM
Just Strokin's Avatar
Just Strokin
The distance you stated is about right for the integrated key remote start/remote entry.
To change the distance you need to install a long range remote start. Ford does have this and it is interfaced with the Premier Perimeter Alarm system and then add a long range antenna and fob.
You can add one of the old style remote entry fobs for longer range lock/unlock.
Old Mar 16, 2017 | 10:31 AM
alloro's Avatar
alloro
This is why I prefer aftermarket ones. With mine it's a 2-way unit with an LCD display. I can start mine from within a building a thousand feet away and see right on the display if it started, if it's locked, if a door is open, or if the alarm is going off.
Old Mar 16, 2017 | 11:04 AM
droldsmorland's Avatar
droldsmorland
Get the app for your smart phone and do it from a satellite
Old Mar 16, 2017 | 02:44 PM
AZLugz's Avatar
AZLugz
You have to hold your tongue between your teeth whilst squeezing your butt cheek hard and pushing the button sequence, works every time, trust me.....
DO NOT get the first two steps switched up or you end up with a crappy taste in your mouth or throwing out your back..
Old Mar 16, 2017 | 07:51 PM
hd1937's Avatar
hd1937
Yes, the same with both remotes and both batteries changed.
Old Mar 16, 2017 | 07:53 PM
hd1937's Avatar
hd1937
I've had that crappy taste before. Now I know why
Old Mar 16, 2017 | 08:17 PM
alloro's Avatar
alloro
Could be from when you owned a Chevy.
Old Apr 10, 2017 | 10:21 AM
DaveNTx's Avatar
DaveNTx
My 2013 F250 is doing the same thing - I used to be able to lock/unlock the doors with the remote from 30-40 yards away, now I have to be just about standing next to the truck for the remote to work (this is after replacing the PATS key battery).
Also, I've had a problem with trying to turn off the panic alarm if I accidentally set it off. The horn won't stop honking until I get into the truck and start the engine (this was happening before the lock/unlock problem started).
Is anyone else having this problem?
Old Apr 10, 2017 | 01:12 PM
seville009's Avatar
seville009
Is it doing it with both fobs (both the range issue and the alarm issue)?
Maybe when you changed the bsttery, either the new battery wasn't really new, or it's not sitting in the fob correctly somehow. Maybe open up the fob and re-set the battery again. Check to make sure all of the contacts are clean while you have it open.
Old Apr 10, 2017 | 01:34 PM
DaveNTx's Avatar
DaveNTx
Yeah, I've been experimenting with both fobs with the lock/unlock range issue (I'll play with the panic alarm when I'm not parked at the house and spare the neighbors).
I just replaced the batteries in both fobs but, the "new" ones I put in had been sitting in the cupboard for a couple of years. I'm going to run down to the store and get a couple of newer batteries and see if that makes a difference.
The original batteries that came with the fobs when I bought the truck were manufactured in Indonesia, now all the batteries are made in China. Chinese made batteries I have had to use in other equipment have been pretty sucky - I suspect that contributes to my problem.
Old Apr 10, 2017 | 02:01 PM
seville009's Avatar
seville009
If you still have problems after doing that, if it were me, I'd disconnect the car battery for a few minutes to reboot the car systems. May not solve anything, but you never know and it's an easy step to try.
mwheue
Oct 25, 2017 10:21 PM
icentropy
Dec 29, 2013 10:27 AM
kylebryan
Nov 19, 2012 11:15 AM
Jim83
Feb 15, 2008 01:17 PM
Artimus
Electrical Systems/Wiring
Feb 4, 2004 10:39 AM
