Sponsored by: Real Truck
2001 7.3 4r100 issue
Old Mar 15, 2017 | 12:22 AM
Psmonkie's Avatar
Psmonkie
New to the site. Have used it several times in the past. My question to keep a long story short is it possible for an over filled transmission to throw a transmission code and not let the trans shift past second? It has 1st 2nd and reverse but that is it. Any help would be greatly appreciated because I am stumped
Old Mar 15, 2017 | 08:04 AM
projectSHO89's Avatar
projectSHO89
What is the "transmission code"?
Old Mar 15, 2017 | 03:19 PM
Psmonkie's Avatar
Psmonkie
Not sure yet. Just my OD light flashing. Have not had a chance to pull the code just yet. Just kinda trying to see what could possibly be
Old Mar 15, 2017 | 03:39 PM
projectSHO89
Get the code(s). Without it/them, all anyone can do is guess which is very speculative.
Old Mar 15, 2017 | 07:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be a wiring issue. It could be a sensor issue. It could be a clutch issue. It could be an internal leak issue. It could be a bunch of other stuff, too.
Old Mar 15, 2017 | 08:20 PM
Psmonkie's Avatar
Psmonkie
Oh by the way I thought I included this in my original post but trans was just installed after a stage 3 rebuild and added a 6.0 cooler.
Old Mar 15, 2017 | 09:26 PM
projectSHO89
Then take it back and have it fixed by whoever did the rebuild under warranty.
Old Mar 15, 2017 | 09:59 PM
Psmonkie's Avatar
Psmonkie
Honestly don't think it's an internal issue. Unless it's a shift solenoid. Speed sensors were both around 1000 ohms. Has a new valve body billet reverse upgraded 2nd and overdrive shift kit and larger pump gears and a billet center support. So before I go through the trouble of pulling the transmission back out and taking it to him to dump 8quarts of fluid out so he can tell me everything is fine with his build I'm trying to get some other opinions and help on things to Chex while it's still in the truck.
Old Mar 16, 2017 | 06:07 AM
projectSHO89
Then you need to get the fault codes like you've already been advised to do.
This is going in a circle. You have to do what you are advised to do, not avoid taking those actions.
Old Mar 16, 2017 | 09:04 AM
Mark Kovalsky
Did you check all of these? You could narrow it down to just what's wrong if you had the codes.
Old Mar 17, 2017 | 12:15 PM
Psmonkie's Avatar
Psmonkie
Pulled codes and got p0782 and p0743. I had to buy another transmission to get hard parts from because mine were completely shot. And the builder said he may have accidentally used the shift solenoid pack from that transmission and it could have been what was wrong with the other one. So I sent the truck to him and he is gonna straighten it out for me
Old Mar 19, 2017 | 03:13 PM
Psmonkie's Avatar
Psmonkie
Took the truck to the builder and he has replaced the solenoid pack with no change. So he replaced the valve body to eliminate it as an issue. Still no change. Now he seems to think it's one of the wiring harnesses and where it plugs into the firewall. Is there anything else that it could be?
jonesy71
May 15, 2018 10:11 PM
jonesy71
May 15, 2018 09:39 PM
IABill
Jul 16, 2010 12:31 AM
Vinford
Nov 29, 2006 07:51 PM
bean440
Feb 4, 2006 04:19 PM
