Sponsored by: Real Truck
Blinking overdrive
Old May 15, 2018 | 12:30 PM
jonesy71's Avatar
jonesy71
Blinking overdrive
My over drive light has been blinking the last 2 days and I can’t figure out why. It only comes on about half way to my drive to work but after I shut the truck off it doesn’t come back on the rest of the day. The truck runs fine and shifts good. What do you guys think it is I read something about maybe the vss but my speedometer works fine. Any simple things for me to try first before I take it in and spend a bunch of money. Thank you
Old May 15, 2018 | 12:44 PM
Mike189677's Avatar
Mike189677
There is a transmission code you need to have the codes read to figure out what the code is. You may have to go to the dealer or a independent shop to hav the codes read as some scanners don't have the ability to read transmission codes. On my last truck the scanner they had at advanced auto would red the trans code that I had but a lot of the scanners at the parts stores don't have the ability to read trans codes. So don't be dead set on just going to a parts store. There is a code get the code and report back and we can guide you in the right direction from there. Also please include the details about your truck in your next post that is important .
Old May 15, 2018 | 06:26 PM
jonesy71's Avatar
jonesy71
So the code is a p0782 a shift error any way that can be fixed with out replacing the transmission. Also my truck is a Ford F-250 2001 7.3
Old May 15, 2018 | 09:39 PM
OneCylinder's Avatar
OneCylinder
When it was new my '03 250 SD, reg cab, 5.4 had a blinking OD light, sometimes, sometimes not as I try to remember. It was under warranty and what they found was that there was a wire harness pinched between the chassis and the bed or the cab I don't remember. The problem never came back to this day.
zer0_13
Aug 3, 2018 06:59 PM
timmyboy76
17
Dec 19, 2017 08:56 AM
kattywumpus
1997 - 2003 F150
Oct 12, 2010 07:23 PM
Saddle Tramp 57
Apr 14, 2006 01:56 PM
RichPSD
Jan 24, 2006 08:09 AM
