SES light came on and lost OD suddenly!
1999 F150 Transmission Problem.
The other day on the way home midway thru a 7 hour trip I stopped for gas, when I was getting back on the fwy, the engine/trans stumbled a bit, the Service Engine Soon light came on and stayed on solid not blinking, and I lost about 250 rpm from high gear at 70 mph like I intentionally turned off OD but I didn't. I made it home the remaining 200 miles and parked it. Tried it today, SES light came on when I started it so Ididn't drive it I just shut it off. The fluid level is good, nice and pink, and no burnt odor, the son-in-law just pulled a "Shift solenoid" code.... what do you think is going on? Is this common?
1999 F150 4x4 5.4 Supercab
Trans code: E (E4OD/4R100??)
This is a GPD/Ford Reman. Trans that was replaced 120,000 miles ago?
SES light came on and lost OD Suddenly!
Here's what I've done so far:
I checked for burnt wires against the rt. side exhaust, OK. I pulled the drain plug and sampled the fluid, there was no metal in it, and I had codes read again, they are as follows... 1744 and 0743.
We reset the light but it came on after 5 minutes driving. The idea that it is the Torque Converter makes sense because when I disengage OD you can feel it shift down....
Is the torque converter on the way out and if so won't it send metal thru the system?
1744 and 0743
It's been my experience on other Fords that you have to fix the first issue so that the electric/hydraulic circuit works properly, then then you often have to replace the TC because its clutch plates have been ruined by the slipping.
The electrical circuit fault could be anything in the circuit from the PCM's internal driver to the solenoid inside the transmission or the PCM itself, more diagnosis is required.
F150vettehauler
2004 - 2008 F150
06-21-2014 06:31 PM
