SES light came on and lost OD suddenly!
Old 03-14-2017, 09:01 PM
Birney's Avatar
Birney
Birney is offline
1999 F150 Transmission Problem.
The other day on the way home midway thru a 7 hour trip I stopped for gas, when I was getting back on the fwy, the engine/trans stumbled a bit, the Service Engine Soon light came on and stayed on solid not blinking, and I lost about 250 rpm from high gear at 70 mph like I intentionally turned off OD but I didn't. I made it home the remaining 200 miles and parked it. Tried it today, SES light came on when I started it so Ididn't drive it I just shut it off. The fluid level is good, nice and pink, and no burnt odor, the son-in-law just pulled a "Shift solenoid" code.... what do you think is going on? Is this common?
1999 F150 4x4 5.4 Supercab
Trans code: E (E4OD/4R100??)
This is a GPD/Ford Reman. Trans that was replaced 120,000 miles ago?
Old 03-14-2017, 09:29 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Check for any of the harness laying on the right exhaust manifold. A lot of times ppl will change the transmission and the harness retainers break during removal. You prob have some wires shorted to ground.
Old 03-15-2017, 07:37 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
What is the exact fault code pulled?
From your description of the symptoms, you probably lost torque converter lockup. Loss of OD would force a much higher difference in RPMs a 70 MPH than reported.
Old 03-17-2017, 10:03 AM
Birney's Avatar
Birney
Birney is offline
SES light came on and lost OD Suddenly!
Here's what I've done so far:
I checked for burnt wires against the rt. side exhaust, OK. I pulled the drain plug and sampled the fluid, there was no metal in it, and I had codes read again, they are as follows... 1744 and 0743.
We reset the light but it came on after 5 minutes driving. The idea that it is the Torque Converter makes sense because when I disengage OD you can feel it shift down....
Is the torque converter on the way out and if so won't it send metal thru the system?
Old 03-17-2017, 10:17 AM
projectSHO89
Maybe and probably not.
1744 and 0743
Most likely scenario that I can see is that there is an electrical circuit concern related to the TCC apply solenoid that is causing it to fail to apply full pressure to the TC hydraulic clutch that is then causing the TC to slip or not engage.
It's been my experience on other Fords that you have to fix the first issue so that the electric/hydraulic circuit works properly, then then you often have to replace the TC because its clutch plates have been ruined by the slipping.
The electrical circuit fault could be anything in the circuit from the PCM's internal driver to the solenoid inside the transmission or the PCM itself, more diagnosis is required.
KING-RANCH02
1997 - 2003 F150
12-09-2015 08:43 PM
F150vettehauler
2004 - 2008 F150
06-21-2014 06:31 PM
AndrewWV
05-12-2014 06:54 PM
jprix
1997-2006 Expedition & Navigator
06-25-2013 10:12 PM
96fdcrew
06-21-2004 07:30 PM
Quick Reply: SES light came on and lost OD suddenly!
