Questions regarding performance with stage 1 and DP tunes
Lots of good info here. I have TW tunes and are not rated in horse power.
1. High Idle
2. daily
3. light tow
4. heavy tow
5. street
6. extreme
I am hoping he "properly" tuned them as he new all what was done or not done to my truck but this all makes me wonder a little. At least I can prove to my wife I need to get a fuel pressure gauge. Boy I cant wait
1. High Idle
2. daily
3. light tow
4. heavy tow
5. street
6. extreme
The high idle I don't understand. Is that for cold climates for startup?
I'm essentially going to have an identical setup to my Max (bubba Jones) on his bronco so I kind of know what to expect, but my chip will have a few more tunes than him, and my truck is a longbed.
I am anticipating to be excited about it. It will be more powerful than my 24 valve dodge ever was, as I left that truck completely stock the 4 years I owned it.
But briefly dipping to 40 or 45 psi every so often won't cause severe injector wear. 30 psi often, not a good idea, I don't think.
It's always recommended to have proper fuel, and with the OBS trucks, that means any injector upgrade should have an e-fuel system. Otherwise you'll have to run in a low hp tune, and then what's the point of having big injectors if you have to run them at 1/2 power because you don't have an e-fuel system to support them.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I definitely plan all the usual mods with injectors, but until then I will have to back off some. I already have an intercooler installed on my truck, but one of the previous owners who did the work I guess never hooked it up. Not sure which one I have get, just know it's there. So if it's still good, I figured it would be cheapest to get the intercooler done first, then e fuel or hpop next. My buddy just got the Bar None kit and feels confident we can build a kit for me now that we have seen what's in the kit.
weekendwarriorfsw32
29
04-14-2011 06:49 PM
greystreak92
1978 - 1996 Big Bronco
05-21-2003 02:49 PM
