Fuel Mod Questions.
Old Dec 31, 2007 | 08:01 AM
Hotwheelbill's Avatar
Hotwheelbill
Fuel Mod Questions.
I will have my chip back from Jody soon and want to do some fuel mods for power and better milage. I plan to use the ITP hutch kit and do the harpoon mod as well. I am not sure about the helper pump mod. With it pushing more fuel, will it decrease the fuel milage? Also , would I need to make any changes to the return lines with the helper pump?
Old Dec 31, 2007 | 08:12 AM
clux's Avatar
clux
It shouldn't change mileage unless your stock pump is weak, and then it should improve your economy. The injectors have to get a full charge of fuel to get proper atomization. You don't need to do anything with the return line for the kicker pump.
Old Dec 31, 2007 | 09:01 AM
Pocket's Avatar
Pocket
With stock injectors a stock fuel pump in healthy condition should be able to feed fuel just fine. On my truck i have the fuel pressure bumped up to about 68 psi currently. On my highest setting I can watch the fuel pressure drop about 4 psi on a WOT run. That's it, and that pump has over 100K miles on it.
Old Dec 31, 2007 | 09:05 AM
Hotwheelbill
Thanks for the replys. I think I will hook up a gauge first and see what I am starting with.
