Sponsored by: Kumho
Brake Bleeders
Old Mar 13, 2017 | 08:06 PM
hharris8's Avatar
hharris8
Brake Bleeders
I have a '86 Fod Bronco that I have changed the brake lines on and the brakes will not stiffen up (they weren't that good before the switch either). The master cylinder leaks a couple thimble full after driving and it seems to pull a little while braking, but both the disc are shiny so the calipers are not locked. The pedal is still soft even if something is going on otherwise. I have tried bleeding having someone pump the brakes 5-10 times and hold it while I bled it and repeated 10 times on each bleeder screw using 32 oz of fluid, but apparently I did something wrong.
All of this to say, have any of y'all used any brake bleeding vacuum kits and which ones would you recommend?
Old Mar 14, 2017 | 12:51 PM
Filthy Beast's Avatar
Filthy Beast
Don't think you did anything wrong with your bleeding technique although I don't like to "pump" the brakes....that's just me, though.
The M/C shouldn't leak at all. From where is it leaking? If it's from the connections, loosen then re-tighten....especially ss lines/fittings....they need to "seat" a bit after changing to 'em. If the leak is from the rear of the M/C where it connects to the booster, it's bad.
Notice any smoke in the exhaust?
How does the booster feel? Try this to check it: With the engine running, step on the brakes, hold it, then shut off the engine. The pedal shouldn't depress more than 0.25" - 0.50". If it does, the booster isn't holding vacuum. Again, with the engine off, pump the pedal a coupla times and hold. Start the engine and take note of what the brake pedal does. If it moves to the floor, or, moves much, the booster isn't holding vacuum.
Replace.
Old Mar 14, 2017 | 03:38 PM
hharris8's Avatar
hharris8
Replace.
The MC is leaking from the lid. I have replaced the seal and it still does it.
I think you got it with the vacuum leak. When I pumped it with the engine running and then shut of the engine the pedal compressed a long way.
Old Mar 14, 2017 | 06:13 PM
Filthy Beast
Good indication the booster gave up the ghost....glad you found it.
Also, check the booster rod for length/adjustment on the old one and compare it to the new one when you get it.....
Old Mar 15, 2017 | 09:24 PM
jetjockey99's Avatar
jetjockey99
If the master is leaking from the cap you most likely have a bad master, it is bypassing internally, pumping from one chamber to the other, causing one chamber to "overflow" and is also your soft pedal problem. Replace it.
Old Mar 16, 2017 | 02:14 PM
hharris8's Avatar
hharris8
OK, so they should never leak correct? someone told me one of my calipers was probably leaking causing this, but my rotors are shiny so I don't think that is the case, though the truck does seem to shimmy when braking.
Old Mar 16, 2017 | 08:57 PM
jetjockey99
They should never leak from the cap, a leaking caliper could cause a soft pedal but not a leak from the MC cap. Also just because the rotors are shiny you could still have a bad caliper, but I would replace the MC first. You may find that the MC is also leaking into the booster so you could also have a booster problem.
Old Mar 17, 2017 | 09:20 PM
hharris8's Avatar
hharris8
Appreciate it. I just ordered that and we'll see what that does. Thanks again.
BGF100
Aug 17, 2016 10:18 AM
JTS1975
Sep 13, 2011 09:35 PM
78 Ranger
May 11, 2007 09:57 PM
SEDUCED
Sep 9, 2005 10:35 AM
stumpknockerr
Jun 23, 2005 02:00 PM
