Dana 44 spicer or 9in?
so I decided to change out my diff fluid today since when I had to replace a rear backing plate due to a brake malfunction and saw a little bit of grime in the axle tube. Apparently I have a Dana 44 for the rear???(2wd f100). I only found that out when I went to get the gasket for the diff cover since I didn't have a drain plug. Is that a good thing or bad, I've always heard good things about the Dana line and it being on a 2wd it kinda threw me a curve ball as from building knowledge of these trucks I love I always thought they were only on 4wd, can anyone enlighten me on this subject?
If it has a removable rear diff cover, X2 on NOT a 9".
http://www2.dana.com/pdf/44DIMSPEC-812.pdf
A thread on it. https://www.ford-trucks.com/forums/1...-rear-end.html
http://www2.dana.com/pdf/X510-SD.pdf
davelength
13
12-13-2009 07:41 PM
Triple Threat
12-02-2002 05:13 PM
