Dana 44 spicer or 9in?
Old 03-12-2017, 10:22 PM
79flat's Avatar
79flat
79flat is offline
so I decided to change out my diff fluid today since when I had to replace a rear backing plate due to a brake malfunction and saw a little bit of grime in the axle tube. Apparently I have a Dana 44 for the rear???(2wd f100). I only found that out when I went to get the gasket for the diff cover since I didn't have a drain plug. Is that a good thing or bad, I've always heard good things about the Dana line and it being on a 2wd it kinda threw me a curve ball as from building knowledge of these trucks I love I always thought they were only on 4wd, can anyone enlighten me on this subject?
Old 03-12-2017, 10:28 PM
cmanka28's Avatar
cmanka28
cmanka28 is offline
definitely not a 9in if it has a diff cover
Old 03-12-2017, 11:47 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,336 Likes on 2,481 Posts
If it has a removable rear diff cover, X2 on NOT a 9".
http://www2.dana.com/pdf/44DIMSPEC-812.pdf
A thread on it. https://www.ford-trucks.com/forums/1...-rear-end.html
http://www2.dana.com/pdf/X510-SD.pdf
File Type: pdf
justcruzin125
04-06-2016 11:47 PM
BigWhite94
09-04-2010 12:29 AM
davelength
13
12-13-2009 07:41 PM
Triple Threat
12-02-2002 05:13 PM
Quick Reply: Dana 44 spicer or 9in?
