found this in distributor....
Old Mar 8, 2017 | 01:58 PM
carbo_nero's Avatar
carbo_nero
Thanks all,
I decided to just start fresh and ordered a rebuild. At least now I have a known quantity moving forward. Thanks all for your help.
Old Mar 13, 2017 | 10:27 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Lee, Do you have any comments on which springs are used from the 925G set?
Carbo_nero, you might want to look into a more modern spark curve, since gas is now a different formulation. (Not that I know what that is exactly...)
Old Mar 14, 2017 | 01:47 AM
carbo_nero's Avatar
carbo_nero
Originally Posted by Tedster9
You'll need to look in the Shop manual to determine the advance curve for your truck/engine/transmission combination.
It sounds a little like you'd be time and money ahead by installing a remanufactured distributor. It will have tight bushings and freely moving breaker plate and also have a vacuum advance can that is more easily adjustable. The factory types are adjusted by removing shims, more modern types like the Crane use an allen wrench through the hose port. Original vacuum cans will often have leaky diaphragms by now.
Distributor advance
Thank you, I did decide on a new distributor. Appreciate the help.
Old Mar 14, 2017 | 01:49 AM
carbo_nero's Avatar
carbo_nero
Thanks, I decided on a new distributor to remove any possible issues, and a pertronix II to top it off. Still rebuilding the water pump etc so I have to wai to see the result but it should be much better.
Old Mar 14, 2017 | 06:50 AM
lee's Avatar
lee
Hi,
If I remember correctly the 925D only comes with 2 springs, a heavy, light? I went with the 928G as it has more variety of springs.
Here's a re-cap of my re-curve.
As from Ford, my total timing (Initial + Mechanical = 36*) was not all in until ~4000 rpm. Research shows that 3000rpm was my goal for my heavy truck. A car could get away with 2200-2500rpm without "pinging".
My distributor has a 13L – 18L reluctor set at 13L. This will equal 26* mechanical advance. The stock springs were a heavy and a medium thus causing the late 4000rpm total timing.
I replaced the stock springs with the Mr Gasket light springs from the set (928G). Mechanical timing advance curve is as follows with 10* initial at 800rpm idle with Vac advance plugged.
10* initial + 26* mechanical = 36* total and it was all in by 2200rpm. This caused "pinging".
I then changed to 1 light and 1 medium spring. Now have total in at 3000rpm. No pinging.
RPM Advance
Both light (pinged) 1 light, 1 Med.
1000 10* 11*
1500 20* 15*
2000 31* 24*
2200 35*
2500 35* 32*
3000 35* 36*
I recommend you experiment with a few different spring combo's to get the total in ~ 3000 rpm. BTW: Try and stay under 38* total...... so, find out what Reluctor you are running and multiply this valve by 2 (mine's a 13, .... 13 x 2 = 26*) subtract this number from the goal (36* in my case) and that is what to set the Initial timing to (10* in my case).
Hope this helps,
Old Mar 14, 2017 | 09:52 AM
Tedster9's Avatar
Tedster9
Very good explanation of determining and adjusting ignition curve. It's kind of a pita, but when done right you'll thank yourself every time you drive it.
Old Mar 14, 2017 | 10:20 AM
carbo_nero's Avatar
carbo_nero
Originally Posted by lee
Hi,
RPM Advance
1000 10* 11*
1500 20* 15*
2000 31* 24*
2200 35*
2500 35* 32*
3000 35* 36*
Hope this helps,
Thank you for your detailed answer. This info is far, far beyond my knowledge but I will bring this to my mechanic's attention. Thank you.
Old Mar 14, 2017 | 11:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by carbo_nero
1967 F100 352 4 speed manual transmission. I just opened it up and both springs are gone.
Distributor ID number: C7TF-12127-M
C5AZ-12192-J .. Secondary Spring (Motorcraft (MS-473) / Obsolete
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
C5AZ-12192-K .. Primary Spring (Motorcraft MS-474) / Obsolete
GREEN SALES CO. has 10.
Old Mar 14, 2017 | 11:29 AM
CougarJohn's Avatar
CougarJohn
Nice job. Lee. Useful, practical information that I will save.
1972-34ton
16
Dec 30, 2018 02:11 PM
petemcl
22
Jan 7, 2012 06:59 PM
CVokie
Dec 23, 2003 01:10 PM
351 power
Oct 12, 2003 07:29 PM
javi2001
Aug 28, 2003 05:11 PM
