Water Pump Replacement Guide....
Old Mar 3, 2017 | 09:23 AM
swmpbgy1's Avatar
swmpbgy1
Greetings all......
I looked in the Tech Folder for a step by step guide to replace the water pump on our 7.3's. Couldn't find one. Anyone know of a good one??
I ordered the pump from Dieselsite....got the pump, 203* thermostat, lower pipe and billet thermo housing.
Any tips? Would you use RTV with all of the rubber gaskets that are supplied? If so, which color of RTV is recommended??
Swmpbgy1
Old Mar 3, 2017 | 12:25 PM
Stewart_H's Avatar
Stewart_H
Check again, it's there.
Stewart
Edit: I just realized it might be "camouflaged" in that you have to click on the "Gooch" coolant thread. The how to and videoes are contained in that thread.
Old Mar 3, 2017 | 01:02 PM
Stewart_H's Avatar
Stewart_H
Fixed.
Tech Folder has been edited to make them easier to find.
Stewart
Old Mar 3, 2017 | 02:05 PM
swmpbgy1's Avatar
swmpbgy1
Originally Posted by Stewart_H
Fixed.
Stewart
Stewart:
That is probably the only article that I didn't look at.....I used it when I changed out my coolant this summer and only associated the article to the coolant types and the process to flush and fill.
Thanks for pointing me in the right direction.....Is there a torque table out there? For the water pump, belt pulley and lower tube?
Swmpbgy1
Old Mar 3, 2017 | 02:40 PM
Stewart_H's Avatar
Stewart_H
Swmpbgy1
I've done so many water pumps I don't even think about it now. I just go by German specs (goodentite), as well as paying attention to how tight they are to begin with.
I've never had a leak or a problem with the 7 or 8 (lost count) water pumps I've either directly wrenched on and changed (5, I think), or the ones I gave help to.
Stewart
Old Mar 3, 2017 | 03:50 PM
Big Sky's Avatar
Big Sky
Make sure you don't lose track of the bolts for the water pump. I laid mine out in the sequence/order I took them out.
The hardest part for me was getting that @#$%&^%$ clutch fan back on....took me awhile with that shroud on.
Old Mar 3, 2017 | 04:35 PM
RBerry9511's Avatar
RBerry9511
I found the easiest way to get the fan clutch on was to hold the fan on and spin the crank.
Old Mar 6, 2017 | 09:27 AM
swmpbgy1's Avatar
swmpbgy1
Would it hurt to pre-assemble my new pump.....install new thermostat and housing as well as the lower tube before I put the pump on the truck? I also have a Riffraff coolant filtration kit to install....was wondering if I should go ahead and install the hose that runs from the pump to the filter housing too??
Does the thermostat housing and lower tube require RTV??
Swmpbgy1
Old Mar 6, 2017 | 02:22 PM
RBerry9511's Avatar
RBerry9511
Swmpbgy1
I would assemble it before installing. I did and it would have been a pain to do the lower tube after install. The therothermostat housing can be done either before or after. I used RTV on both, not sure if it is required but I didn't want to have to go in and fix leaks after. Hope this helps.
Old Mar 10, 2017 | 09:28 AM
swmpbgy1's Avatar
swmpbgy1
Greetings all.........
Water pump, 203* thermostat and Riffraff coolant filter kit all installed without a hitch!
Running cool now.....er I mean an little warmer now.....
Thanks for all of your help!
Swmpbgy1
6ohman2004
Dec 26, 2024 12:49 AM
Supercab
Nov 13, 2017 01:08 PM
bbender85
Apr 7, 2014 09:39 AM
jchosler
15
May 1, 2010 05:44 PM
pminne
Nov 30, 2007 09:54 AM
