Water Pump???
Old Nov 12, 2017 | 04:03 PM
Supercab's Avatar
Supercab
Water Pump???
What brands of water pumps is everyone using these days?
Old Nov 12, 2017 | 05:55 PM
pirschwagon's Avatar
pirschwagon
I use OEM (since you have the Coolant Filtration)
Old Nov 12, 2017 | 06:42 PM
CousinCarl's Avatar
CousinCarl
I was in a pinch and put one in from oreillys last month. It is lifetime warrantied but had I had the time, I think I would have gone with the one Riff Raff has to offer along with that billet t stat housing.
Old Nov 12, 2017 | 10:22 PM
KelVarnson's Avatar
KelVarnson
I just did the one from RiffRaff, and also their billet housing. The pump looked good on inspection, and the install went very well. Zero leaks. I can't advise you about the longevity yet, obviously, but I spent a lot of time looking at pumps online and reading threads, and that all led me to the RiffRaff one. I have a good feeling about it.
Old Nov 12, 2017 | 10:24 PM
timmyboy76's Avatar
timmyboy76
Airtek, 81.00 from rock auto...170k
Old Nov 13, 2017 | 04:57 AM
Supercab's Avatar
Supercab
Back YEARS ago when I did my first one everyone was using the Airtex pump and it was said that they were the original manufacturer to Ford for the pumps.
My pump itself isn't leaking-it is leaking between the pump and the front cover at the top.
I actually replaced my pump a few years ago because of this and even ordered an OEM seal from International.
The darn thing still leaks at the same place....
I am going to remove the pump one more time and use some sort of sealer on it this time and thought in doing so that I should replace the pump and not just put the old one back on....
And here I thought that the fancy seal was the end all to using any sort of sealer....
Old Nov 13, 2017 | 05:41 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
The one Riffraff sells.
Old Nov 13, 2017 | 06:51 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I installed the IH pump from DieselSite because I was very new to the 7.3 world. If I had to do it now, I would have pieced the IH pump together myself and gone a much cheaper route with the good product. Alternatively, the pump that RiffRaff sells is good too.
As for leaking the same spot, make sure there is not a burr or something there with a light scrub from some emory cloth.
Old Nov 13, 2017 | 10:44 AM
Supercab's Avatar
Supercab
Thanks! My cooling system is spotless thanks to that filter and the Peak Final Charge Coolant!
Old Nov 13, 2017 | 10:47 AM
Supercab's Avatar
Supercab
Thanks! I'm going to do absolutely everything I can to insure that the new pump doesn't leak-this is going to be it for a LONG time.
Old Nov 13, 2017 | 10:50 AM
Supercab's Avatar
Supercab
Sooooo The pump that RiffRaff is selling is made in China.....obviously a copy of the original because it has no numbers on it the way I understand it.
Any ideas as to where the one that Ford sells (Motorcraft) is made? Airtex?
Are any pumps made in the USA??
Old Nov 13, 2017 | 11:04 AM
Sous's Avatar
Sous
FTE Emeritus
You could try rock auto or white bear nation ford.
Old Nov 13, 2017 | 01:08 PM
liquidlounge's Avatar
liquidlounge
I'm pretty sure Alliant makes a pump for the 7.3 and a good chance it is US made. Some of these guys on here have so many layers of Chinese parts on their trucks, its no wonder all they do is work on them. I don't get the $125.00 for a $10.00 part as opposed to $175.00 for a $100.00 part. O'rielly can give you 3 starters or water pumps in a year under warranty and still come out ahead!!
6ohman2004
Dec 26, 2024 12:49 AM
microdevil45
Nov 9, 2011 03:32 PM
shoebear
May 2, 2010 05:43 PM
Benjoman
Nov 23, 2009 07:46 PM
brown 4x4
Mar 29, 2009 11:26 PM
