I've seen a bad shock bushing do this on one of my superdutys. Usually when you feel it in the floor though, it's sway bar. But you said you already did those.
Just dropping in to see if maybe you ever figured out your problem? I have pretty much the same thing going on. On turns I get a pop sound just one..... Already replaced body mounts, end links & even new front leaf springs......
Hope you can provide some insight!
I ended up replacing the body mounts and that fixed the creaking sound. As far as the pop goes I replaced the front ball joints and that solved that problem. So far so good. No new noises YET
