The motor what is it ?,Looks like a 330 ,2bbl !,the water pump has regular inlets,its not the hd !,block reads 352 58 left front of block,near the oil filter{ 42 dif } lower is k-12 ,intake reads C7TE (9425-k) 9k10 ,Vin F61CCH0221 on door !.,the valve cover has 5 bolts !,oil pan straight on the bottom. Without knowing the internals,casting on the crank/dowel check,What about cast numbers on the heads?. any Thought on this Idenification of this motor !!,Thanks for your Forums !! Harley 589 !!
Harley, what did this engine come from ? Is it still in its original truck ? Does the engine mount with one big mount under the front or are there two mounts, one on each side of the block ? DF
Hi DF:The motor is mounted in it,{ F-600,1970},Yes, front engine mount!. 4 holes on the each side of the block !Check today,an seen the intake goes under the valve cover!,also pulled the valve cover off,cast # on the head is 9k27,The spark plugs angle is // \\ on the head. Thanks much for the reply !!. Harley589.
harley, I think the engine in your F-600 is an FT because according to ford engine parts interchange book 4 holes on each side indicate a FT "ford truck engine" like a "FE' but heavy duty.
Displacements were 330,359,361,389,391. 330, 359 had 4.00in bores. 361,391 4.05in bores. Don't know what one it would be,but considering it is post 60's I would assume 361 or391.352 casting in your block began with 352 eng in1958 and remained with FE throughout its service life. Hope this helps Jakes69.
Hi Jake thanks for the info!,iam trying to idenifi this motor ?,for a rebuild or go a 391,heard that if it is a 330 md,????,Iam just better to find a 361 HD -Up Block !!.Will a 391 /370/360/ bolt in ?,will a 370 /360 work? Wish i new what motor i have ??.Thanks Harley589 !
Barry you are correct with the vin id!,It does look like the pictures,can i take the exhaust casting numbers to indentify it? Thanks again !!, Harley589
