86 f350 dually 4x4?
86 f350 dually 4x4?
I was under the impression the 83-86 Ford f350 duallys never came in 4x4. I'm looking at possibly picking up a new work beater and its an 86 f350 4x4 dually with a service bed on it. Almost looks like a nine footer so maybe it's a cab and chassy?
460/t19. Be a good potential for 6.9 swap if the 460 craps out. Already have a motor on stand by that's low miles on a rebuild.
Any input on if any of these duallys were 4x4 would be appreciated. It's got the Dana 60 front axle too, although I prefer the ride of a ttb. I'll try and see if she's just got adapters or something next time I get a chance to look at it.
Received 3,114 Likes
on
What you may also see is a spacer-conversion - basically a 2" or so chunk of aluminum which bolts to the wheel hub and has a set of studs in it for the wheels; it just spaces the flange on both sides out far enough for a set of offset dually rims to fit.
This *could* be a problem as you would be putting extra force on the wheel bearing... but the wheel bearing in the Sterling 10.25" full-floating rear axles(used in a lot of IDI-powered trucks, not sure about the early years) is extremely large and can handle the extra strain easily.
My understanding is that factory-dually rear axles have the same bearing, just slightly longer to not need the spacer.
I haven't had a chance to look at it again but if it is running spacers they are the cast iron versions. I have a set of these on standby if. I ever feel like buying six tires.
I would agree that the rear axle can handle the extra stress. The front end on a dana 60 would probably be fine too rather than a 44/44hdttb/50ttb
I'll try and snag the vin and see what exactly it decodes to.
toddclem
10-15-2011 11:03 PM
jwrboss302
09-26-2008 12:09 PM
