Battery problems anyone?
Old Feb 27, 2017 | 08:01 AM
msgtord's Avatar
msgtord
I've had to jump start my truck 3 times now. The first time I thought it was my fault for playing the tunes to long while cleaning up the truck.
The second time, I let the timer shut everything down after the first cycle, thinking it would save the battery. Nope had to jump it.
Then I'm at my son's place doing some work, no stereo at all. Just going in and out of the truck several times over the course of 4 hours. Had to jump it.
I know that the computer shuts down the alternator to save fuel, as I watch the volt meter fluctuate between 12.7 and 14.3 volts.
Has any one else had this issue? I'm thinking I'll just put in a stronger battery and get rid of the factory 610 amp.
Thoughts?
Old Feb 27, 2017 | 10:44 AM
GlueGuy's Avatar
GlueGuy
I would suspect a faulty voltage regulator.
Old Feb 27, 2017 | 11:28 AM
johndeerefarmer's Avatar
johndeerefarmer
Bigger battery will help a little but it's still going to be an issue if you only take short trips
Old Feb 27, 2017 | 12:42 PM
GlueGuy's Avatar
GlueGuy
If the battery is fluctuating like that while the engine is running, there is some kind of fault in the charging system; either battery or regulator. The running voltage should not drop below approximately 13.5 volts.
Old Feb 27, 2017 | 02:21 PM
msgtord's Avatar
msgtord
I wonder if its the voltage regulator, or the system shutting down the alternator to save gas. I read an article that stated the number one complaint on the newer vehicles with all of the technology is the battery.
The same thing happened with my Super duty and I had a new battery installed with no more problems.
Trip to the dealer tomorrow.
Old Feb 27, 2017 | 05:04 PM
GlueGuy's Avatar
GlueGuy
A resting battery with no load is going to be in the area of 12.7 to 13 volts depending on how long it has been since disconnected from a charger (after a day or two it might go lower).
If the battery is in a charging circuit, I would never expect the voltage to go below "about" 13.5 volts, which would be the approximate "float" voltage. I have numerous solar installations (nothing to do with trucks or cars I grant), and the lowest a solar charge controller will let a 12V battery get (as long as there is sun), is about that 13.5 float voltage.
Given any kind of discharge from full, a charge system will go up to what's called the absorption voltage of "about" 14.5 volts. The exact voltage is dependent on the charge system, and the battery chemistry, but that's a good ballpark.
Old Feb 27, 2017 | 07:22 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I cannot say I have continuously watched the voltage while running Dashboss, but the voltage has always been 14+ volts in my truck.
You need to visit the dealer for a systems check.
Josh
Old Feb 27, 2017 | 07:49 PM
msgtord's Avatar
msgtord
I watched it close this afternoon and never saw below 13.5.
Old Mar 1, 2017 | 05:54 AM
msgtord's Avatar
msgtord
Follow up:
Took it to the dealer and dispite 3 times having to jump start the truck, the battery and system check good.
Old Mar 1, 2017 | 07:36 AM
Tom's Avatar
Tom
Have them check for parasitic draw. The fact that this never happens with the engine running means your charging system is probably operating fine.
Old Mar 1, 2017 | 08:54 AM
GlueGuy's Avatar
GlueGuy
I agree with Tom. Either your driving habit is too short to fully charge, or you may have something drawing down the battery when the truck is "off" (which it never really is).
I don't know what the typical parasitic is, but I would expect it to be in the low milliamp range.
Old Mar 1, 2017 | 03:50 PM
mikemtn's Avatar
mikemtn
New 2016
I've had this new truck for a week and I've seen some symptoms of a battery problem. Auto stop/start don't work, Sync 3 screen shuts down, some stuff like radio don't remember what was showing when I turned motor off. But, the biggie is at one time I saw on the Sync 3 screen a battery gauge that showed the battery about 1/2 full. Unfortunately, I cannot find that gauge again.
Old Mar 1, 2017 | 07:32 PM
msgtord's Avatar
msgtord
I unplugged my maglight charger, removed the headlight delay and turned off the DRLs. I think the culprit is a combination of the maglight charger and weak 610 CCA battery. It doesn't drain while parked overnight, just if I play the tunes with the engine off, or just going in and out of the truck while working. It should at least have the same battery as the lariat, considering all of the power requirements.
Old Mar 1, 2017 | 09:46 PM
GlueGuy's Avatar
GlueGuy
I play the radio/bluetooth with the engine off all the time. Drive with headlights and foglights on most of the time. I leave the doors open for extended periods with the truck all lit up like it was Christmas. I am not having any battery/charge issues at all.
Old Mar 1, 2017 | 09:49 PM
Tom's Avatar
Tom
They don't have a weak battery, but yours was likely made week by deeply discharging it. Lead-acid batteries never fully recover from a deep discharge, and after a couple of times yours probably has severely diminished capacity.
My '15 has the largest factory battery of anything I've ever had save for my diesel Super Duties, and I've never killed a battery unless leaving something plugged in for a week.
