My vote is the battery that went completely dead while on the lot.
Not to insult anyone, but a short lesson.
Almost all car batteries are comprised of Six 2 Volt cells on a common buss. The voltages applied to the car battery via the alternator or charger are for the entire buss.
In other words, a 12v battery that is at a 13.8v charge cycle is under optimal (and theoretical) conditions has 2.3 volt charge applied to all of the cells
If you have a dead or weak set of cells the voltage applied to the system gets absorbed by the other "good" cells. So a dead cell would cause the other cells to be charged at roughly 2.76 volts. That voltage is enough to destroy a good cell in short order.
Testing with a multimeter only gives you buss output voltage.
Since you have no way of isolating the cells with a meter, a total battery voltage can only give a sort of insight as to what might be happening.
A strong cell compensating for a weak or dead cell will easily mask a problem via a voltage check.
However, its capacity will be drastically reduced.
More over, the cells that a now being overcharged to compensate for the weak cells will rapidly deteriorate with each charging cycle.
So again, the symptoms as described above easily fit with why I think that battery went dead at one point before you even bought it. If you EVER see a Dealer jumping a car to get it started (not that you did in this instance) demand a new battery.
I'm glad to see they made it right.
Makes a lot of sense. I think I'll get up in the morning and go shake the tree and see if I can get a new battery.
So a 610 amp should be plenty if it's new? Or should I put in a higher amperage battery? I tend to go for the overkill! You know if 610 amp is ok, I tend to sleep better if I go with a 800 amp. ☺ Can you have to many amps?
Had to jump it again this morning after playing the stereo for one cycle. I put the charger on it and will see how it does after a good charge.
I did do some research and realized my truck was built in Nov 15. It set on the lot until I bought it in Oct 16. That's the longest a vehicle has set at the dealer that I have ever purchased.
IMHO...if this happens again, then I recommend calling FORD service for a tow to your local dealer. These instances should be documented...and YOU should NOT allow a jump start if offered.
After two or three or more tows to the dealership, then I would believe they'd change out the battery. Or...at the very least owe you a detailed explanation.
YES...it is a total inconvenience, but these issues need to be documented by FORD service. Helps you in the long run.
Good luck with it!!
biz
Your right for sure. The problem is I really hate going to the dealer. I have 2 jump boxes and a battery charger. I'm accustomed to fixing most of my own problems. To go to the dealer and have to wait around for 3 to 4 hours while someone repeats what I have already done, or like last time, it checked ok, and sent me on my way.
I'm sorry, but that's just silly. Declining a jump start would likely mean he would be billed for the tow, because it's completely unnecessary. I can tell you from experience that having the truck towed won't do anything for the warranty process. My Transit was towed five times for a strong crank, no start, and nobody gave a crap how it got to the dealer.
They owe you road service because the truck is under warranty and that's their stated coverage. They don't owe your truck a ride on a rollback when it can safely get there on its own.
Yes, the 610-amp battery is perfectly adequate. The battery doesn't give a crap about electrical accessories because they are powered by the alternator as long as everything is functioning right. My '15 would start flawlessly at -20° with the factory battery without using the block heater. There's no reason that you need a bigger battery.
High CCA batteries are a good plan if you live in North Dakota or Saskatoon, places like that. Arizona and Texas, from your profile, it's not necessary. Can't have "too many" amps, but high CCAs come at the expense of reserve capacity and are more easily damaged and may not last as long.
The only way to truly test a battery is with an amp draw tester. make sure the battery is charged before testing. If you have a bad or week cell it will show itself.
Come to think of it...the worst cold start I've ever had was in December at -27°, and I didn't have a power outlet I could plug the block heater into. Cranked slower than usual, but fired off after less than three seconds. The Odyssey wouldn't have started at all in those temps.
I really can't imagine any reason why the factory battery capacity is inadequate.
Well, we are at the end of the odyssey. I took the truck to the dealer and this time left with a new battery.
I did observe that my volt meter read 14.5 volts at start up. It's never read higher than 14.1, even after a 300 mile trip. Normally it was 13.5 to 13.8 around town.
13.8 - 14.3 is right in the ballpark at 70F Nobody measures when it's Zero out for some reason but the proper charging voltage goes up in cold weather to overcome internal battery resistance. 15+ is typical below zero.
As stated previously, the only sure way to check out a battery is to take it out of the vehicle and put it into a tester. Because each of the cells in the battery (there are 6 cells in a 12 volt battery) is independent, and you do not have test points on each one, you have to extrapolate the condition of the cells by putting it through a charge/discharge test.
By the sounds of it, you had a battery with at least one bad cell. Glad you got it fixed.
