late 99 no start!!
Old 02-25-2017, 07:14 PM
David7.3's Avatar
David7.3
David7.3 is offline
late 99 no start!!
Ben a while guy's since I have had fun playing on FTE website, Got sucked into installing a set of stage 2 single shots from full force diesel. they reburned the chip, and I just stated to get everything back together, when I pulled the chip out of the computer with my foot. Truck died, no fuel pump, no tach, no wait to start light, and a constant check engine light. Did the obvious fuses, relay's, wiggling of the harness, ect. still waiting for the tow truck to drop her off.
any one with a good idea I'm listenin
Old 02-25-2017, 07:20 PM
Sous's Avatar
Sous
Sous is offline
Received 4,572 Likes on 2,900 Posts
I assume the truck was running fine until you dislodged the chip with your foot? You may need some PCM work, but that is only speculation at this point.
Old 02-25-2017, 07:27 PM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
I am with Sous on this too. If the ignition was on when this happened you may have damaged the PCM.
Old 02-25-2017, 07:28 PM
David7.3's Avatar
David7.3
David7.3 is offline
Yea she was running fine, for about a week, then this happened, I'm thinking PCM too.
Old 02-25-2017, 07:38 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is online now
Received 1,665 Likes on 1,545 Posts
I posted in the welcome section. All info I have indicates connection or disconnection of ts-6 or similar devices with power to the ecm will cause damage. I would say it will need to be replaced.
Rod
Old 02-25-2017, 07:56 PM
David7.3's Avatar
David7.3
David7.3 is offline
Rod
Thanks Rod! Love your poem, I feel the same way!! I think this thing wasn't right since it got wet from the windshield disaster years ago. oh well guest the mortgage is going to have to wait.
Old 02-25-2017, 10:11 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Swamps is repairing PCMs now for about $475. Much cheaper than a rebuilt PCM for $900+ https://swampsdiesel.com/products/fo...build-service/
I toasted my PCM last year. Troubleshooting water in the IDM, and removed the chip with the key in the ignition. Fried the memory module in the PCM. You have likely done the same. Cost me $900 to get a new one, and that was only because I used my brother's Ford account at his dealership. Would have been about $1100 without the discount.
Old 02-26-2017, 08:05 AM
David7.3's Avatar
David7.3
David7.3 is offline
I just borrowed my buddies snapon solus ultra. cant communicate with anything, made sure I have power at the obd terminal and cant read codes, cant even do a buzz test. So if I cant talk to the PCM swamps is were to go. Figures. thanks for the input, which my PCM wants nothing to do with!
tbirdscott
05-13-2013 09:02 PM
Orr353
07-03-2011 02:39 PM
jleal_21
71
12-12-2010 06:17 AM
Pocket
16
10-25-2009 11:17 AM
Mattyp
19
12-22-2006 07:56 AM
Quick Reply: late 99 no start!!
