Shut Off,now wont stay running/NEED HELP
Ok, Here is the story... i have a 2000 F-350, 183,xxx miles...Drove for around 100 miles a couple days ago,almost got home,and the motor just cleanly shut off...and then would not restart,no wait to start light or anything...got it home,let it set over night...tryed to start again,and it started up and ran for about 5 seconds then shut back off. Replaced the CPS last night with a OEM ,started it up and then it ran fine for about 3 minutes,then shut back off again, there is also no Check engine light ,tach is not jumping when cranking and there is fuel in the bowl...What could it be ? What are my options ? And just for more info,the motor is completly stock,just straight pipe, Auto transmission....
Did you buy it new? Reason I ask is because it may have a chip. I would check that and my PCM connections first.
Here is a writeup on how to install a chip. Just follow the instructions for the PCM R&R. Maybe with the batts disconnected and a reseating of the connection will get you back up and running.
If your PCM ends up toast, DPTuner sells them for a good price.
Originally Posted by Mattyp
No,i bought it used with 161,XXX miles...and im pretty sure it does not have a chip in it...Should i try to find another PCM and try that ? Everything in the truck still seems to work fine,WTS light, no CEL's...
well,all 3 in the BJB under the hood (the smaller plastic cover). and the fuse can seem fine and still not be making good contact, but in this case I'm leaning towards those relays
Tenn.... could this be that sensor on the HPOP that you sometimes talk about unplugging to put the truck in "LIMP" mode?
Update, i let the batteries charge back up,unplugged every fuse,relay,and sensor i can find and plugged them back in to make sure everything weas making good contact...cleaned the battery terminals...now, the truck start right up and runs for about 5 minutes or so and shuts right back off ! this thing is driving me crazy...Im gonna go drink some beer and watch some TV,Maybe that will help it out a little bit egh ? Let me know what you guys think. and BTW thank you guys for helping me out with this so far.
Well,got the truck back two days ago,it was the valve on the bottom of the fuel bowl,it was leacking slowly...so i guess maybe it was not getting enough fuel maybe,he replaced it...and it fixed the problem so... ::Cheers:: Thank you guys for your help,this is a great forumn...i'll stick around for sure !
