1978 - 1996 Big Bronco
L/R turning radius not equal
Old Aug 29, 2003 | 07:23 PM
andym's Avatar
andym
I thought this was a little odd. I just noticed it recently, too. My Bronco has a very tight turning radius when making a right turn. When I make a left turn, it turns a like a loaded river ferry. It keeps catching me off guard, and I keep screwing up at parking it.
What could cause this? Bad alignment? Bad tie rod end?
Old Aug 29, 2003 | 08:20 PM
DW2455's Avatar
DW2455
sounds fishy! maybe bent steering arm, maybe it just likes going one way. DW
Old Aug 29, 2003 | 09:30 PM
96bronco58's Avatar
96bronco58
Have you checked the stops, one may be adjusted different. Its a small bolt toward the front of the lower caliper bolt. They souldnt move out, but you never know
Old Aug 31, 2003 | 11:05 PM
wild4wd's Avatar
wild4wd
has the pitman arm been removed i know this sounds strange but i had a 79 4x4 and had same problem so i straighten the wheels and checked position of pitman arm it was off 1/4 turn i guess prev owner did it his self and with the steering box shaft having slots cut at equal places he replaced it in wrong slots.. i actaul had tire rub one way and almost no turn the other..hell i got the truck for 800.00 dollars i cant complain..hope im helpful
ahub421
Large Truck
May 12, 2016 07:06 PM
built tough
Sep 22, 2011 12:59 PM
xc4jokestomper
17
Oct 23, 2010 09:26 AM
skips69
Paint & Bodywork
Jul 13, 2004 06:50 AM
cajunbull61
Jan 13, 2004 07:12 PM
