I'm not sure if there is a way to predict it. I will have to get ahold of him and see what the symptoms werewere if any diff than what has been observed. I wish Byron would pull his already
I'll be doing it here in the next day or two when life settles down.
Originally Posted by z31freakify
Not that bad I IIRC there's 4-5 bolts the hard part is removing the Harmanic balancer, and since your there replace the oil pump seal and race.
I have read only 4 bolts once the balancer is off.
Are we saying that low oil pressure from the LPOP causes the HPOP to fail?
Does abnormally low pressure from the LPOP starve the HPOP and cause rapid wear and tear, thus creating brass contamination that is observed in the oil?
If so, what is the lowest acceptable LPOP pressure? Mine never drops below maybe 25 psi at idle when its hot, and tops 50 psi at normal operating speeds.
I'm interested in this question too.
Do you have a separate gauge and if so, where did you install the sending unit?
