Sponsored by: Auxito
Dim head light
Old Feb 24, 2017 | 06:19 PM
Camble's Avatar
Camble
Dim head light
Hi guys i know this is probably a repeat question, but this is what i have.
I have a 2000 Ford F150 4x4 extended cab the passenger side head light is very dim try and turn on high beams and it does not react while on low beam the high beam indicator in the cab is on. Where can I look or what is the common problem for this.
Thanks again
camble
Old Feb 24, 2017 | 06:39 PM
Tedster9's Avatar
Tedster9
Most likely a loose, missing or corroded ground strap
Old Feb 25, 2017 | 08:23 AM
steve(ill)'s Avatar
steve(ill)
I would guess the ground is bad and you don't have a full 12- 14 volts ............. remote possibility is the head light switch. ............. check voltage at the light plug or add a temp ground wire.
Old Mar 8, 2017 | 09:11 PM
Travis S's Avatar
Travis S
+1 here. Clean the grounds behind BOTH headlights and re-test. If it's still acting funky, pull the dimmer switch (multi-function switch), bypass it with a jumper wire and see if that makes them work properly. If so, you got a dying switch as mine was when I got it. I replaced the switch (Rock Auto is your friend here, I got an original Ford part for $12!) and modified the circuit to retrofit some relays so the new switch will last forever. All the heavy 'work' is done by a cheap, easily replaceable relay instead of a specialized part.
Old Mar 8, 2017 | 10:56 PM
Tedster9's Avatar
Tedster9
A 2000 model year already uses headlight relays does it not? Maybe not, just wondering.
Old Mar 9, 2017 | 04:33 AM
projectSHO89's Avatar
projectSHO89
Nope. The 04 MY was the first to use a separate relay for the high-beams. Low beams were still controlled by the light switch/MFS series circuit.
Check the ground for the rt headlight.
Old Mar 9, 2017 | 06:51 PM
Travis S's Avatar
Travis S
Ford finally comes kicking and screaming into the 1980s, 25 years after everyone else...
Okay, joking aside, retrofit some generic parts store relays into the circuits. Open the harness up on the driver's inner fender, separate the correct wires (see the FSM for them) and cut/splice accordingly. They're not too hard to access, the hardest one to splice is the main headlight power wire from the fuse box. My truck has two identical wires in this bundle, the corrct one is deeper in the harness. Bit of advice: don't guess, confirm it with a continuity test to the appropriate fuse BEFORE YOU CUT by probing the wire you want to check This location (4" from the fuse box) really sucks to make a splice in if you screw up.
Overall, the mod isn't too hard. I did it i the dark in 4" of snow with only a tiny freebie flashlight from Harbor Freight.
Old Mar 10, 2017 | 05:44 PM
Tedster9's Avatar
Tedster9
Relays are a good idea, but the underlying fault, some kind of bad ground should probably be remedied.
Old Mar 13, 2017 | 09:26 PM
awsumdc's Avatar
awsumdc
Hey Guys, haven't posted in awhile.
sorry to hi jack this thread but I thought it would be better than staring a similar one. I just picked up a 2001 f250 Lariet with 180K on it from my brother. I'm having the same problem but on the drivers side. Dim lo beam and no high beam on the drivers side. Changed the bulb and still the same issue. Where might I find a schematic for this truck that gives me locations of the grounds. Thank you very much. Wyatt
Old Mar 14, 2017 | 09:16 AM
alloro's Avatar
alloro
Here is the diagram along with the ground location.
File Type: pdf
File Type: pdf
Old Mar 14, 2017 | 10:09 AM
projectSHO89
Yep, check G100 for the driver's side. you may need to check it back to the headlight connector.
singlguy9
Nov 19, 2018 08:03 PM
dirty diesel 07
Dec 7, 2007 08:49 AM
Shojna
May 13, 2007 03:40 PM
kmans777
1983 - 2012 Ranger & B-Series
Oct 1, 2005 08:01 PM
