59 Head light switch
Old May 7, 2007 | 04:55 PM
Shojna's Avatar
Shojna
59 F100.....I think I have a head light switch issue but want to be sure before I order a new one. Highs and Lows light with dimmer set to high. Lows do not light when dimmer set to lows. Dimmer has been replaced. Switch also pulses when in the on position. Any ideas?
Thanks,
Steve
Old May 7, 2007 | 05:14 PM
hiball3985's Avatar
hiball3985
if its pulsing, thats the circut breaker ( no fuse on light switch circut) cutting out due to overheating, usualy from a short, could be something internal in the switch going bad, or a short somewhere in the wiring
Old May 9, 2007 | 09:51 PM
Shojna's Avatar
Shojna
Thanks...I bought a new switch from Rockauto but will check the wiring before installing it this weekend.
Thanks,
Steven
Old May 9, 2007 | 10:05 PM
2many56s's Avatar
2many56s
Low beam circuit has a breaker on the firewall(or at least thats where mine was) take a piece of wire and connect the one terminal to the other terminal, the low beams should come on(remember to have dimmer set to low) the headlight switch only supplies the power to the dimmer and will supply power no mater high or low. If the headlights do not come on at all, then its usually the breaker, if they come on then go off quickly or just flash then you have short tripping the breaker. If in doubt, unhook it and ohm check it. -2many
Old May 10, 2007 | 08:57 AM
Shojna's Avatar
Shojna
Thanks...what does this breaker look like and where on the firewall should it be? My manual does not show it.
Steven
Old May 10, 2007 | 10:11 AM
2many56s's Avatar
2many56s
My 1959 manual only mentions it, mine was at the top of the firewall, near where the clutch master would be, has two posts in/out.
Old May 10, 2007 | 02:01 PM
hiball3985's Avatar
hiball3985
I think the breaker is built into the switch on a 59, it is on my 60
Old May 10, 2007 | 06:40 PM
2many56s's Avatar
2many56s
1959 and 1960 wirring is completly different. So are the switches......
Old May 10, 2007 | 09:13 PM
economan's Avatar
economan
check all the h/l connections and grounds, especially the grounds, that'll make the breaker overheat fersure.
one night mine started acting up real bad then quit all together, was over an hour from home. ended up hadwiring h/l's directly to the battery to get home, thats when i noticed the wire was realllly hot, so that pretty much diagnosed the bad grounds........i cleaned em up, notta problem since (10 yrs)
mikie
near ottawa canada
58 merc panel, 64 econo p/u
Old May 13, 2007 | 03:40 PM
Shojna's Avatar
Shojna
Mikie,
Found the breaker and replaced it. I also replaced the Headlight switch and re-wired the tail lights..........Everything works great.
Thanks,
Steve
pbuxton
Nov 8, 2008 03:57 PM
stroker85
Feb 9, 2008 06:51 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
macwilj
Jul 28, 2007 08:26 PM
borcht warrior
Jul 20, 2007 01:47 PM
