Heater restore and fan switch
Old 02-24-2017, 08:49 AM
bhalemail's Avatar
bhalemail
bhalemail is offline
This is the heater that was in my truck when i bought it years ago. It is the "Firestone" model from what i understand. The core has very small leak when i tested it with 10 lbs of air pressure so i'm going to take it to the radiator shop and see if they can clean it and fix any leaks for a reasonable price. The heat/defrost cable works fine and i'll thread the end and put a new **** on since the old one is pretty much disintegrated. The one question i have is where can i find a 6V switch for the fan? It was completely missing (just a bare wire going to the fan is all that remains). I test the fan on my 6V battery and it runs nice so i think i'll just need the switch but i can't find any repops. I'm not sure if there's just one speed or if it's rheostat type thing either? Any ideas?
Old 02-24-2017, 09:39 AM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,733 Likes on 1,516 Posts
Would the 2 speed switch from a stock heater work? Like this type here.
Old 02-24-2017, 10:05 AM
bhalemail's Avatar
bhalemail
Abe i think so. That's kind of the setup i have now (one for fan, one for defrost)
I found a Borg Warner S180 6V switch for a couple dollars that i'm going to try out. My friend owns a NAPA and thinks he has some NORS switches for 6V that will work. I need to find out if the core is repairable first before i spend any time or money on this one. I think i'll drop that off today and see what i find out.
Old 02-24-2017, 10:29 AM
abe's Avatar
abe
abe is online now
Where do you take your cores?
Old 02-24-2017, 10:49 AM
bhalemail's Avatar
bhalemail
I open for suggestions but the place that i'm aware of that still does them is up lycoming creek road, union auto. There is a place called the radiator shop in williamsport but i've never been there
Old 02-24-2017, 11:25 AM
abe's Avatar
abe
abe is online now
There is a guy in Mill Hall his name is Jeff Weaver. He has a radiator repair and garage. He is good and cheap. He is on Peale Ave by the bridge. Number is 726.3870, cell 6607595.
Old 02-24-2017, 10:53 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Do you have the license plate that matches the DAV key chain?
Old 02-24-2017, 11:01 PM
abe's Avatar
abe
abe is online now
Nope. That would be cool.
Old 02-25-2017, 06:40 PM
firstrider's Avatar
firstrider
firstrider is offline
Switch
Like this ?
laudy57
11-19-2017 07:01 PM
jvmcc
08-13-2016 02:38 PM
lemonshindig
03-21-2010 07:47 PM
ford81
12-24-2005 10:15 PM
cje07
1978 - 1996 Big Bronco
03-12-2003 03:26 PM
Quick Reply: Heater restore and fan switch
