Heater restore and fan switch
1 Attachment(s)
This is the heater that was in my truck when i bought it years ago. It is the "Firestone" model from what i understand. The core has very small leak when i tested it with 10 lbs of air pressure so i'm going to take it to the radiator shop and see if they can clean it and fix any leaks for a reasonable price. The heat/defrost cable works fine and i'll thread the end and put a new knob on since the old one is pretty much disintegrated. The one question i have is where can i find a 6V switch for the fan? It was completely missing (just a bare wire going to the fan is all that remains). I test the fan on my 6V battery and it runs nice so i think i'll just need the switch but i can't find any repops. I'm not sure if there's just one speed or if it's rheostat type thing either? Any ideas?
Would the 2 speed switch from a stock heater work? Like this type here.
https://cimg2.ibsrv.net/gimg/www.for...a2121f216c.jpg |
Abe i think so. That's kind of the setup i have now (one for fan, one for defrost)
I found a Borg Warner S180 6V switch for a couple dollars that i'm going to try out. My friend owns a NAPA and thinks he has some NORS switches for 6V that will work. I need to find out if the core is repairable first before i spend any time or money on this one. I think i'll drop that off today and see what i find out. |
Where do you take your cores?
I open for suggestions but the place that i'm aware of that still does them is up lycoming creek road, union auto. There is a place called the radiator shop in williamsport but i've never been there
There is a guy in Mill Hall his name is Jeff Weaver. He has a radiator repair and garage. He is good and cheap. He is on Peale Ave by the bridge. Number is 726.3870, cell 6607595.
Originally Posted by abe
(Post 16979499)
https://cimg2.ibsrv.net/gimg/www.for...a2121f216c.jpg Do you have the license plate that matches the DAV key chain? |
Originally Posted by Moe Craig
(Post 16981491)
Switch
1 Attachment(s)
Like this ?
