Heater rebuilding
Old Feb 22, 2017 | 02:04 PM
Amphihauler's Avatar
Amphihauler
Heater rebuilding
I have a new foam kit from an early bronco supplier and everything looks like it will fit just fine but I'm trying to figure out which side of the metal flaps to apply the foam to. Anyone had theirs apart that had good factory foam on the flaps? Mine was completely dissolved into dust so can't really tell.
Old Feb 22, 2017 | 03:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which fresh air heater does your truck have, Economy or Deluxe?
Deluxe has two cables located on a bracket mounted under the dash to the right of the steering column.
Old Feb 22, 2017 | 06:18 PM
Amphihauler
Deluxe with the two under dash cables.
Old Feb 22, 2017 | 08:10 PM
Cal250's Avatar
Cal250
Trailering
I rebuilt mine with the same kit, but it came with instructions that showed which side the foam went on. I will see if I have the instructions still laying around.
Old Feb 22, 2017 | 08:39 PM
Cal250's Avatar
Cal250
Trailering
Here is a copy of the instructions provided. The foam is facing down in the picture and wraps around the end a little bit. That way it seals the opening when the flap is closed.
Hope that makes sense.
Old May 15, 2017 | 06:17 PM
Amphihauler
Figured I'd post an update. I installed the seal kit and used an upgraded fan sold by Toms Bronco. Did a new heater core while I was at it along with new hoses and heater valve. Everything works fantastic and the fan blows really well. I recommend that fan to anyone out there doing the heater.
https://www.tomsbroncoparts.com/prod...uper-high-flow
Dave Burner
Dec 8, 2018 06:03 PM
f100jim
General Automotive Discussion
Dec 8, 2014 12:16 PM
nerksa
25
May 19, 2013 05:01 PM
firefighter23114
Feb 2, 2010 06:50 PM
Ervie
Mar 21, 2008 05:46 PM
