'66F250 heater box
Old Dec 8, 2018 | 05:22 PM
Dave Burner's Avatar
Dave Burner
'66F250 heater box
Does a 1966 Bronco heater box fit/replace the OE heater box on a 1966 F250? Looks the same. Can't find a '66 F series heater box on line, but several Bronco sites have them.
Old Dec 8, 2018 | 05:33 PM
resonateur's Avatar
resonateur
Dave
I have an original if you need it.
eric
Old Dec 8, 2018 | 06:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bronco heater is completely different, will not work.
1965/66 F100/1100: There are TWO different fresh air heaters.
The deluxe fresh air heater has two *****/cables mounted to a bracket, located under the dash to the right of the steering column.
One cable operates the door that allow fresh air to flow into the heater box. The other cable operates the heater water valve, that is spliced into the inlet to heater core heater hose.
The economy fresh air heater has a manually operated heater water shut-off valve, located in the same place as the cable operated heater valve, no cables under the dash.
Both heaters have the heat control and blower motor switch located on the dash to the right of the choke cable.
Pic: Here's the Bronco heater, it no more looks like either 1965/66 heater than a mule looks like a henway!
6t6merc
Jan 30, 2023 01:36 PM
Speedjester
Jan 24, 2015 04:17 AM
mezapu
Jul 20, 2011 01:53 PM
Andrew7dg
Jan 13, 2011 01:04 PM
germans1966
Nov 7, 2009 07:04 AM
