Retractable Antenna
Old Feb 20, 2017 | 10:59 AM
74F100LGM's Avatar
74F100LGM
Retractable Antenna
Is there a decent retractable antenna option available for a 93 F250?
It can be manual I'm just looking for something I can lower a bit in the garage.
Or even a replacement mast which is a bit lower?
Old Feb 20, 2017 | 11:53 AM
Freightrain's Avatar
Freightrain
No real room on there trucks for retractable antenna. It only mounts to the cowl panel and no room below that I recall for the rest of the assembly.
Don't recall how the little ball fits on the end, but you could snip the top and glue the ball back on.
The length is predetermine for optimal reception. I suppose you won't really notice a change.
Old Feb 20, 2017 | 12:00 PM
74F100LGM's Avatar
74F100LGM
Thanks for the reply. I've seen retractables on other cars that don't retract into the cowl, but into itself. You're left with maybe 1' above the cowl? That does what I need it to.
In fact I think my '74 F100 is like that - it's just not in front of me to verify.
I'll take a look for perhaps a shorter fixed mast.
Old Feb 20, 2017 | 02:26 PM
Diesel_Brad's Avatar
Diesel_Brad
no room on these trucks
the 73-79 had a retractable antenna but they still were about 12" tall retracted all the way
Old Feb 20, 2017 | 02:54 PM
Freightrain
Ya, my '69 has retractable, but only to a point. I'm betting it is the same basic antenna mount so you could look at putting something like that on.
I used to unbolt my '69 antenna and lay it on the window when I covered it up in the winter.
muecker
Dec 11, 2018 08:33 PM
Rod Bensken
6.7L Power Stroke Diesel
Jul 15, 2012 02:51 PM
schmidt64
Jan 8, 2006 08:16 AM
kbosch74
1997 - 2003 F150
May 4, 2004 12:50 PM
BigSean
Jul 14, 2003 02:33 PM
