Antenna recommendation
Old Dec 10, 2018 | 02:14 PM
muecker's Avatar
muecker
Any half- or medium-height antennas that you guys recommend? I'm tired of banging on the garages when I pull in. I've done Stubby on my other trucks and was not satisfied with the loss of reception, so I would like to go mid or half height if possible. Thanks.
Old Dec 10, 2018 | 02:30 PM
delorenzomp's Avatar
delorenzomp
I did see a late model F150 with a replica munitions cartridge as the antenna, it was approximately 4"-5" tall (at a glance), I would guess the basic 'rubber ducky' replacements would be effective too (if you get past the appearance)...
Old Dec 10, 2018 | 02:33 PM
delorenzomp
I just saw that I missed your stubby statement...others on this forum have removed the ball tip (by cinching an adjustable wrench on it and giving the wrench an upward 'whack' (be sure to follow the ball)...then cut off a bit (they say it does not noticeably affect reception) and then return the ball to the antenna (probably after grinding-off any burrs )...
Old Dec 10, 2018 | 02:47 PM
Poncho450's Avatar
Poncho450
I went with a rubber stubby at first. A) I thought it looked kind of goofy. B) It lasted a few months, but one time it didn't come home from the car wash. So I'd seen the suggestion above. I twisted the ball off the top with pliers. Cut the antenna to a length that would fit under my garage door and epoxied the ball back on. Many months and dozens of car washes later, still there and still works with no appreciable difference. Could have save myself $20 or so if I'd done that to begin with.
Old Dec 10, 2018 | 02:57 PM
muecker's Avatar
muecker
Thanks, Y'all. I'll try to modify the length of the stock antenna. Appreciate it.
Old Dec 10, 2018 | 04:15 PM
jimzpsd's Avatar
jimzpsd
Take a propane torch to the ball, GENTLY heat it up,.......... slides right off. Do the same to replace it..........slides right on.
Old Dec 10, 2018 | 04:55 PM
delorenzomp
Great tip, jimzpsd !
Old Dec 10, 2018 | 05:04 PM
Towerhog's Avatar
Towerhog
This is similar to the one Im using with no issues.
Amazon Amazon
Old Dec 10, 2018 | 05:31 PM
GABAR's Avatar
GABAR
Look for one in the 13-21 inch range and you should be okay.
Old Dec 10, 2018 | 06:02 PM
TCNashville's Avatar
TCNashville
https://www.amazon.com/gp/product/B0...UTF8&amp&psc=1
Exactly the one I bought, easy to install and no loss of reception.
Old Dec 10, 2018 | 06:40 PM
HRTKD's Avatar
HRTKD
I bought this one also to avoid the garage door. I would argue that there was some loss of reception. Maybe 15%? Hard to gauge. I carry the OEM antenna under the back seat. The loss of reception wasn't bothersome enough for me to swap the two antennas.
Old Dec 10, 2018 | 09:23 PM
cjindna's Avatar
cjindna
Initially ordered a 21” replacement and found it to be too short. Wound up then ordering the 27” which runs just an 1” or so higher than the top of the cab providing some level of early warning for potential low clearance roof damage.
AntennaMastsRus - 27" Black... https://www.amazon.com/dp/B078L4GTNY?ref=yo_pop_ma_swf
Old Dec 11, 2018 | 07:37 PM
Motown82's Avatar
Motown82
Tagging this for later
Old Dec 11, 2018 | 08:33 PM
slip knot's Avatar
slip knot
I bought a generic shorty from Autozone. @10in long. After dragging the original all over the parking garage in Houston. I haven't noticed a big loss of reception, but I listen to Sat. radio mostly. I might modify the OEM mast to just a hair over the roofline. like the idea of using it as a height gauge.
mtl-biker
Feb 5, 2019 06:53 PM
Rod Bensken
6.7L Power Stroke Diesel
Jul 15, 2012 02:51 PM
Gage2502
Jun 28, 2011 04:35 PM
HappyJack
Kansas Chapter
Dec 30, 2007 09:59 AM
BigSean
Jul 14, 2003 02:33 PM
